I have a 2022 CS-S and upgraded to a Renogy 200ah with bluetooth that shows the current draw via the Renogy DC Home app. With all things off, I see a draw of about 1.7 amps. Is this a typical draw on your Tab? Is that draw caused by one or two components or the sum of a bunch of little indicator lights? Seems like a lot for having everything off (even the display on the Jensen is off).
Loving the large battery... I'm trying to dial in the available power while boondocking.
What's your battery draw when everything is off?
2022 Tab 320 CS-S Boondock
0 ·
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
Right now, parked back at home, closed up, I see a draw of 0.
The inverter is shut off. I've verified multiple times that no accessories are turned on: no fridge, no usb, no lights, no pump, no heat, no a/c, no microwave. The fridge is turned to zero. The radio is lit up, so that's on.
I even shut off all breakers and pulled each fuse, 1 at a time, but the Victron connect app continues to show 6-9 amps being drawn. What could be causing this and/or can you suggest a way for me to determine what's drawing power?
Attaching some pictures. With battery switch off (zero draw, small solar charge)
With battery switch on (drawing power 7.92A) .
Battery switch off, charging 6.4A:
Battery switch on, drawing power 2A while charging 6.6A (so net draw about 8.6A):
Just a long shot...is it possible the pin for your e-brakes could be pulled or just out enough? That is a big draw and around the amount e-brakes pull?
I don't have them, but doing a quick search I've seen specs for battery heating pads across the board from very low amps to 4-5 depending on the type (internal or external). Are the heating pads fused somewhere that you could pull it and observe any change or are they internal to the battery BMS?
Southern Maryland
Switches are outside USB, inside USB, Stereo, Blu-Ray, TV.
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
Southern Maryland
managed by VE Smart Network
About 4 yrs ago I did a lot of testing to track down which electronic devices were accounting for our background "phamperage" when everything was "off"..
https://tab-rv.vanillacommunity.com/discussion/comment/121905/#Comment_121905
I subsequently installed several kill switches to alleviate most of the background current.
2023 T@B 320 S Boondock
