I have a new BOONDOCK. Have not even been camping, yet. I have solar. All worked fine until I turned off the batteries with the switch. Now the solar won’t charge, the batteries won’t charge and I can only run shore power to use anything electrical in the rig. Of course, I did turn the batterie switch back to the on position. I checked the breakers and the fuses. Could it be the switch? Any ideas would be very helpful. Thank you.
0 ·
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
What year is your TAB 320? Also, what is the problem? Your solar is not charging your battery? Same as above, it was working until you turned your battery switch Off/ON? TAB 320's have no DC circuit breakers, only fuses. The only circuit breakers are for the AC power located in your WFCO.
Southern Maryland
2023 T@B 320 S Boondock
