Possible to add Boondocks style front rack to older 320?
Undertheradar
Undertheradar Member Posts: 11
edited January 2024 in Camping & Travel
Hi all.  Will be picking up our new to us ‘15 Tab 320 and I’m wondering if the aluminum tray/box setup from the newer Boondocks trims would be a simple bolt on?
  • SLJ
    SLJ Member Posts: 659
    These guys can tell you if it will fit:
    https://seabiscuitmetaldesigns.com/
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
    edited January 2024
    @Undertheradar - do you mean both the Boondock platform and diamond plate tub?
    Contact help@nucamprv.com to confirm.
  • dsfdogs
    dsfdogs Member Posts: 641
    I added the platform from nuCamp to my 2018 and also replaced the plastic tub with the new aluminum version. I had to order through my dealer and they also installed for me. They included these items with a shipment of trailers so I avoided the high freight cost. Then I added two side tubs from Sea Biscuit Metal Designs. Now, Sea Biscuit makes a platform and middle tub plus a full width middle tub! The added storage was a game changer plus the updated look was nice. Just be aware of tongue weight depending on your tow vehicle.
    Debbie in Oregon
    Sold 2023 Tab 400
    Sold 2018 T@B 320S
  • mgreen2
    mgreen2 Member Posts: 89
    NuCamp sells it for 2019 and newer because that is when they started using it. Contact AllPro and ask about fit on a 2015
    Cargo Platform – Allpro Adventures
  • mona
    mona Member Posts: 246
    I had the boondocks tray minus the aluminum box added to my 2015 a couple of years ago.
    Jeanne
    2015 T@b S Max  white with silver trim. 2018 GC Trailhawk.
  • Undertheradar
    Jeanne
    Awesome, thanks.
  • AnOldUR
    AnOldUR Member Posts: 1,757
    edited January 2024
    Have you considered a truck box? This one came from Tractor Supply, but a search should find a lot of other options from forum members. It was more work than a "simple bolt on", but not too bad and well worth it.
    (overnight stop at a Harvest Host brewery)
  • Undertheradar
    That looks really great!  Mind sharing the model # or even just the dimensions?
    Thanks!
  • AnOldUR
    @Undertheradar I'm not having any luck finding my receipt for the box. On the Tractor Supply website I'm only seeing one that's painted black, but the dimensions are the same (57in. x 20in. x 19in). Price has gone up. Pretty sure I paid less than $300. Shouldn't be too hard to find an unpainted one, maybe from a different supplier.
    https://www.tractorsupply.com/tsc/product/tractor-supply-56-in-chest-box-matte-black
  • Undertheradar
    Perfect, thanks!  I’d actually prefer black.  :)
  • StepheninDen
    StepheninDen Member Posts: 56
    Totally agree about going with a truck box. When I bought my 2014 TAB CS-S a few years ago, the original plastic tub was damaged and had to be replaced. I scored a used 5’ long truck box and had it mounted by an RV mechanic. First and best mod I’ve had done. I’m sure the new nucamp platform and boxes are great but I love having one big open space. Lets me carry longer things like a 36” long folding table that might not fit in those smaller boxes. Plus even buying new, it’s probably still cheaper. Just be careful about tongue weight. If you stuff it full plus propane and battery, you might be a bit front heavy 😁.
  • Brynnraen
    Brynnraen Member Posts: 1
    Our 2014 320 S Maxx has one! The previous owner had it installed, but it is clearly doable even in older models.
