I have purchased a used 2015 CSS and need to sanitize the fresh water tank and system before camping for the first time. I've read where people state their drain is to the left of the step by the door. I don't see anything there. Can anyone with a 2015 CSS tell me where it is and what it looks like? I see this under the kitchen in the back-left of the trailer. But all I see is a red and blue hose. I don't see any sort of valve to drain the fresh water tank under the stove. Is the valve inside, under the sink??
And this is what it looks like under my sink/stove. If these are the drains, is there a valve inside that opens those up so I can drain the fresh water tank before sanitizing?
And the valves to open these drains are located under the sink/stove in the kitchen galley.
What is the additional blue line--the one with no apparent valve--that exits the floor just to the left of the fresh water tank valve? I've noticed nothing like that on the S model.
2Cougs did you finish the manual?
I have a 2015 Tab CSS and trying to figure things out. Thanks for your help!
Something I did was borrow a label maker and labeled all the valves.
"Just Enough"
