I'm about to pull the trigger on a mattress topper from Mattress Insider. I usually sleep wheel-to-wheel and leave the side benches up. I measured the "actual" sleeping area as 38" x 69" -- which leaves a little gap between the pads and the side walls.
I called Mattress Insider and they recommended the Brookside topper, and suggested I could use the 35" x 72" size, which is one of their standard sizes. Advantages being (1) it is in stock and (2) a little less expensive than having a custom size made.
I am wondering about the 72", which will cram the topper up against the side walls of the camper. Will the topper be in the way if I need to fold up the seats to get something from the storage underneath? Is there any concern about air flow if the topper is crammed against the walls (that is not where the air vents are for the heating)? Anyone else use a topper of this size?
Thanks.
2018 T@B 320 S Boondock | 2015.5 Volvo XC60 T6 AWD | Seattle, WA, USA
0 ·
Southern Maryland
https://www.amazon.com/gp/product/B00004X12T/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
If the cost difference is small, and you are not in a hurry to get the pad, I would opt for the custom size.
However…losing 3” width wise would drive me batty. I don’t mind a twin size width, but smaller than that and I’ll eventually find myself rolling off the edge on one side or the other.
Thanks all for the input!
https://www.mattressinsider.com/rv-mattress-topper.html
Ordered my topper today from Mattress Insider. Thanks again for the input. I measured, and remeasured, several times. I decided the length should not extend past the hinges in the rear bench, so measured that at 69". For the width, I measured the actual pads of the rear bench, making sure to leave room for the Lagun table support, so that is 37". The sales rep said that 69" is shorter than most people go with (recall he previously suggested the 35" x 72" in-stock mattress. I just don't see how you could easily make up a bed that is crammed against the wall like that. Fingers crossed I did the correct thing.
The custom size 37" x 69" priced out at $149, which is only $20 more than the standard size. They project 1-1.5 weeks to produce and ship. As someone who wallows in "analysis paralysis" it is a relief to finally have this decision finalized. Now if I can just get my 70 pound golden retriever to be less of a bed hog, we'll both be very comfortable.
Glad you were able to make a decision…I absolutely can relate on analysis paralysis! So frustrating.
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
Full (double) sheets have a very loose fit, I'm wondering if a jersey fabric sheet in Twin size would stretch in width to fit better than a full size sheet.
Southern Maryland
I’m out of town from our TAB so I can’t measure.
Southern Maryland
