After learning about the WFCO issues with auto detect, I checked out the charging status of my 2023 tab 400 with the battleborn 100ah lithium. The led was ‘green’ and the charge voltage limit was in the 13 volt range versus recommended 14.4v.
So, I wrote to WFCO and got the ever friendly Shaun technician. He asked me what my software version was, and I could not find it anywhere on the face plate of the charger, even after multiple suggestions from Shaun. He then, oddly, offered that I should not have any problem with my auto detect. I wrote back that I really just wanted the jumper solution based on the forum experiences I’d read from many. Doing what WFCO recommended, didn’t seem to make it sticky to a lithium charging profile. Shaun replied that he’d ship a jumper out that day, which he did!
Picture attached. No instructions, just the jumper. I guess my email confidence implied skills with the converter. There probably aren’t that many six pin connectors on the circuit boards, right? The shrink wrapped jumper appears to be a resistor folded in half and pressed into the blade connectors of locations 5 and 6 (marked) of the six pin plug. I didn’t cut off the shrink wrap, but would if asked, before I install it to benefit others with the AD issues.
My only question is whether there are instructions for jumpering the 8955-AD. I recall instructions for the 8755, I think.
Thanks all.
Rob
For fun I searched the WFCO literature for PCB images of the 8955-AD product.
The best image (below) has One Six Position Connector location = = J4 = =
Image however does now have the Header installed, mate for the Jumper Plug they shipped you.
2015 Audi Q7 TDI
Northern Ohio
I have no idea.
Suggest you open-up the Power Center and inspect the installed PCB . . . it might have the socket.
If not, take a picture and send to WFCO support person that provided the 'jumper' and ask for guidance.
Let us know what you discover/learn.
2015 Audi Q7 TDI
Northern Ohio
2013 Tundra TRD 5.7L
Massachusetts
Maybe they will put a darn Switch back on the PCB.
2015 Audi Q7 TDI
Northern Ohio
Massachusetts
2015 Audi Q7 TDI
Northern Ohio
Step six: slide the converter back in place and secure withe the two screws. Step seven: Turn on 12 volt power and check for blue light. Step eight: replace and secure the trim cover.
Total time to complete the jumper insertion (converter to Lithium) 10 minutes
Massachusetts
Thanks for the install details. Easier than I’d ever hoped! Will try it soon. Love that blue light.
2015 Audi Q7 TDI
Northern Ohio
Massachusetts
2015 Audi Q7 TDI
Northern Ohio
2015 Audi Q7 TDI
Northern Ohio
Poor picture. There is heat shrink on the resistor obscuring the color code as well.
Jericho, VT
Reportedly the WFCO is sensing a current draw of more than 20A to switch to Li mode. The 8ga wiring would not prevent that. I can attest (as would others) that the unit does indeed switch to Li in this case. The problem is it can and does revert to lead acid mode under some conditions.
My guess is there is an adjustment on the WFCO which would limit the 55A to less than that, but likely not something WFCO would let slip as the same adjustment would allow more than 55A and overstress the unit.
Jericho, VT
2015 Audi Q7 TDI
Northern Ohio
Moved the batteries inside and ran 6 feet of 6ga between the batteries and loads (Eventually going to install a 50A Orion XS). For the first time ever the blue light and cooling fan came on right away. Saw 20A at first, but was close to 100% so it’s been dropping steadily for the absorption phase.
So I don’t think there was ever a problem with the WFCOs. NuCamp just shouldn’t have installed such a long run of 10ga between the load center and the batteries.
OK, but real world nüCamp and nearly every other RV builder is not doing ideal installations
{layout issues, cost, marketing over-ride physics}.
So, IMHO, WFCO fouled up making the unit automatic instead of having a simple SWITCH for the user to set.
If enough of us ask for the "free jumper fix" WFCO might just decide to put a Switch Back In . . . has got to be cheaper than all the US Postage and Support Staff Time.
In these typical unit pictures you can see the LED glow to the left and behind the Fuses.
Remember, as this and dozens of other posts across every RV Forum - - -
the Auto-Detect needs a near dead battery to 'auto set' the charging profile.
