The Alde owner's manual advises renewing the air cushion after 10 days of use by opening the safety/drain valve for a few seconds. It goes on further to advise emptying the hot water tank after 10 days of use to form a new air cushion. I've read topics related to the air cushion on the forum but don't recall anyone specifically discussing doing this after 10 days of use. Is this a standard procedure for many of you long time contributors?
To empty the hot water tank, I am guessing that the valve and small white port labeled Hot Water Drain just below the Cold Water Drain aft of the driver's side wheel is the appropriate valve to open to empty the hot water tank. Once emptied, should it be refilled from the fresh water tank using the pump or by connecting to city water? Is either method suitable?
Susan & Bill, Yarmouth, Maine
2024 Kia EV9
0 ·
Most of us empty our Alde and fresh water tanks and drain the plumbing lines after a trip to prevent any overgrowth of bacteria. We do not travel with water in our tanks, so, before relocating on a trip, we empty.
When re-establishing the air cushion it doesn't matter if the Alde system is off or on.
1. Turn off city water or the pump (if dry camping) so there's no water pressure.
2. Open a hot water faucet and leave it open.
3. Open the yellow valve for a few minutes (the longer the better) to let water drain out.
4. Return the yellow valve to the horizontal position. 5. Close water faucet.
6. Turn water back on. Open a hot water faucet. If it hisses and pops (pushing out air until water flows smoothly) you've done it correctly.
He said to do this every 7-10 days of camping. If out for months do it every 5 days.
It shouldn't matter which method you use to refill the tank. Either City Water or using the pump.
Thus, the question for me has been, which is accurate? Release some pressure for "a few seconds," or "empty the tank" every 10 days?
I have always followed what I refer to as the "10 in 10" rule..............that is, open the safety drain valve for 10 seconds, every 10 days. That has worked well for me, without any issues. It seems like a logical way to create the air cushion, particularly because the cushion is "at the top of the tank."
The instructions you received at üCamp sound like a combination of those for creating an air cushion and emptying the hot water tank. I also find it interesting that the Alde rep apparently said it does not matter if the system is "on" or "off" when creating the air cushion. I say that, because their manual includes a "WARNING," which specifically advises to never open the safety drain valve while the system "is under water pressure and/or still warm."
Finally, I recall that @pthomas745 wrote the following (back in August 2022), which may be the explanation for the discrepancies, although it is not clear from the Alde manual:
Check the manual again: the section about the air cushion says maintain the air cushion after 10 days of use, not "non-use." And, then the "Notice" says to "drain the Alde Tank after 10 days of use". (On the various Alde web sites and videos, this is described as "continuous" use. There is no description of the need to do it if you are just "occasionally" using the Alde hot water. (Alde Safety/drain valve Questions (vanillacommunity.com)
1). The air cushion issue applies only to the Alde hot water tank and the trailer’s hot water lines.
2). The only yellow valve you need to open to produce the air cushion is the one on the hot water line; you don’t need to open the yellow valve on the cold water line.
So far so good, I guess. Where I get off the Truma train: doing this every 5-10 days on a road trip. On a 6-8 week trip I typically do it once. And to be honest, I haven’t followed the intricate procedure prescribed by the Truma sales rep - I just open the valve for about 15-20 seconds. I never have drained the tank to establish an air cushion.
2025 Silverado (EV) or 2019 Colorado (ICE)
2018 T@B 320 Sold
Racing the Wind and Chasing the Sun
Virginia Beach, VA
2024 Kia EV9
2024 Kia EV9
The cold low point drain will also drain the main Alde tank, but not the Flow tank. (Not sure if you have one). The yellow flapper would need to be raised to drain that. At the end of a trip, I drain everything.
We have traveled long distances from Ohio to the Southwest and we do not camp when in transit, so, our water management may be different compared to someone who camps along the way. Hope this helps.
Stagnant water will begin to grow, especially inside the trailer's water lines and fresh tank. It is both prudent and recommended to drain the water system when the trailer is not actively in use. Allowing the water to remain in the trailer for extended periods of time will cause bad things.
Pre-Nautilus trailers empty the hot water tank through the normal water drains or the Alde pressure relief valve. Post-Nautilus trailers drain the hot water tank through the Alde pressure relief valve only.
As a technique, we close all valves, faucets and pressurize the water system the morning before getting on the road. We carry 1/3 tank of fresh water. If we decide to stop before the destination, everything will work. On the way home, we open all the drains, the bath faucet, and the kitchen faucet. We leave everything open until the next trip. Airflow and dry lines will keep the system clean. We are rarely gone more than 5 days. Refilling the system for the next trip will establish the airspace for hot water expansion when the Alde is turned ON. Note: the airspace is only needed when the Alde is ON.
"Just Enough"
2024 Kia EV9
2024 Kia EV9
2024 Kia EV9
2024 Kia EV9
2024 Kia EV9
Check out ScottGs Plumbing Schematic here. It is helpful to understand the plumbing. Of course, this is pre-Nautilus, but the layout is the same. If you check further down in the link, I believe there are some owner-made Nautilus system schematics, too.
https://tab-rv.vanillacommunity.com/discussion/7856/plumbing-resources#latest
To figure it out, pressurize the trailer with water. Disconnect the water source. Open the low point drains. When it stops draining, open the yellow pressure relief valve. See if water comes out the Alde drain. It will not come from the low point drains.
My trailer is pre-Nautilus. For the Nautilus, I only know what I have read.
"Just Enough"
"Just Enough"
2018 T@B 320 Sold
Virginia Beach, VA
Commercial and residential hydronic systems- whether heating or domestic hot water- by code must have devices or copper loops to accommodate thermal expansion. How is it Nucamp failed to do this on a 40K machine?
As I understand it, the glycol loop expands back into the glycol tank behind the toilet.
The hot water loop has nowhere to go?
If H20 density decreases from roughly 62pcf at STP to 60 pcf at 195F and we have a 2.1 gallon tank plus line, the ~3% to 4% expansion creates how much pressure increase? Unless that drives the psi in the system far above 40 psi I would not be concerned.
Here is one example of a device that would probably obviate all this angst and tunneling under the bed...
https://supplyonline.com/rectorseal-exptmini-thermal-expansion-tank-w-1-2-in-mip-ss-connection.html
along with a valve
https://www.zurn.com/products/water-control/thermal-expansion/model-bvecxl
Please don't rush out and buy these, I'm just speculating.
Bill
