I recently purchased a new (to me) 2018 T@B 400 and plan to tow it with a Ford F-350 (one ton) pickup. I now discover that towing with a one ton truck is not recommended due to possible damage to the trailer frame. Getting another tow vehicle is not an option. Would using an "air bag" hitch on the truck help the situation? Any other suggestions?
One possibility I've found:
https://shockerhitch.com/product/shocker-air-receiver-hitch/
Can you ever have too much truck?
TV 2025 Telluride X Type
This post predates my time on the forum so I wasn't aware of this "limitation". My trailer doesn't have any label to that effect though, and while I understand the reasoning it would also imply that the "Boondock" models are not meant to be taken off pavement. Or subjecting the frame to a 1000hp Cybertruck ?
Had to read up on this!
After the slamming we've taken on some concrete (dis)jointed highways, I wonder how much worse a stiff suspension would be?
Could rename a camper the T@boom!
You might try towing for a while first, and then decide if you need to invest in heavy gear.
Regardless, do inspect the Rivnuts that hold the Tab frame together as a few folks have seen failures.
I did keep that email, just in case.
For what it's worth, I've seen no issues yet towing with that rig.
SW Montana USA
Unless you are literally driving the wheels off of your 350, where is the harm in towing with it? You have more torque and more horsepower. Does that mean you will be driving like Johny Force and accelerating hard enough to pop the frame rivets in the Tab? Doubtful. If anything, the extra HP will allow you to drive more gently. Starting from a standstill on a steep hill? Ease away. If you have a Subaru TV you'd be giving it everything it has. What does the trucks suspension have to do with how the Tab is sprung? Goose egg.
Yes, the 350 could pull your 400 at 70, 80, 90 on the Interstate. Would you? Most certainly not. Judge Harvey rules in favor of the big truck. Let er rip. Go for the King Ranch.
Virginia Beach, VA
When I had my 320 S bearings serviced, when the tech brought my trailer out upon completion (connected to a forklift), he showed me how much play the frame has, by rocking it up and down (by grabbing the exterior T@B handle and moving it in an up-and-down motion. That concerned me a bit, but maybe it is normal for a T@B? Other than the tech bringing it to my attention, I have not noticed any unusual movement. Another tech at the RV shop said the movement is not unusual, but I do not know what he based that on. Regardless, it has made me wonder exactly how the factory at nuCamp attaches the frame to the chassis. As best I can tell, they use carriage bolts.
If anyone knows, or even better, can post some photos, that would be great.
I was confused by the reference to the "frame rivets." Although many use the terms "frame" and "chassis" interchangeably, I consider the trailer frame to be the load-bearing structure (aluminum framing) that surrounds the living area of the trailer, whereas the chassis is the support structure below the body and floor of the trailer. Regardless, my question would be better posed as a separate topic for discussion.
Again, and as you note, you can drive the wheels off of the T@B with any vehicle. It could be a Jeep, a Subaru, a King Ranch, it matters not one bit. Hook it up and haul it like it's a precious and pricey accommodation or drag it around like it's your neighbors borrowed utility trailer. That is what will make the difference. Bounce it down some dirt roads at 25 mph and over a few RR crossings. That is what puts stress on the fasteners. You can just as easily shake the house apart with a Half-ton truck.
Virginia Beach, VA
2022 TAB 400 Boondock “Boo”
2024 Jeep Gladiator Mojave
