2024 T@B 320S - lug nut
Hi. We are picking up our Tab on Friday.  I was thinking to put lug nut covers on each wheel lug, but do not know what the size is.
my order size options from Temu are 17mm, 19mm, 21mm.
thanks
  • jamesdn1948
    jamesdn1948 Member Posts: 13
    Lugnuts are 19mm (3/4") on my 2023 320.
    Jim
    2023 Tab 320S
  • Freespirit
    Freespirit Member Posts: 187
    You may want to check your lug nuts before you purchase lug nut covers. I just discovered today that on our TAB the lug nuts have covers on them. I would be surprised if not all TAB’s already have lug covers.
    2020 TAB 320 U
    TV 2025 Telluride X Type
  • Freespirit
    2020 TAB 320 U
  • YanniLazarus
    YanniLazarus Member Posts: 371
    I ordered these from E-trailer for my 2020 320S (non-boondock). Perfect.
  • Slackers
    Slackers Member Posts: 490
    I replaced ours with solid (non-acorn) lugs. The new lugs are also compatible with those on our TV, so a single lug wrench (or socket in our case) works for both TV and Tab.
