2024 T@B 320S - lug nut
LouiseL
Member Posts: 19
Hi. We are picking up our Tab on Friday. I was thinking to put lug nut covers on each wheel lug, but do not know what the size is.
my order size options from Temu are 17mm, 19mm, 21mm.
thanks
thanks
Lugnuts are 19mm (3/4") on my 2023 320.Jim
2023 Tab 320S1 -
You may want to check your lug nuts before you purchase lug nut covers. I just discovered today that on our TAB the lug nuts have covers on them. I would be surprised if not all TAB’s already have lug covers.2020 TAB 320 U
TV 2025 Telluride X Type0 -
Just found this earlier post
https://tab-rv.vanillacommunity.com/discussion/comment/7234#Comment_7234
2020 TAB 320 U
I ordered these from E-trailer for my 2020 320S (non-boondock). Perfect.Yanni Lazarus 2020 T@B320S, 2018 RAV4 Adventure, Central CT0 -
I replaced ours with solid (non-acorn) lugs. The new lugs are also compatible with those on our TV, so a single lug wrench (or socket in our case) works for both TV and Tab.2019 Tab 320 CSS, 2019 Ranger TV, OH0
- 143 Events & News
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
