2007 T@B
Rockford, IL
2007 T@B
Rockford, IL
I could be mistaken, but my understanding is one shouldn't lubricate threads where a nut is to be torqued to a specified setting.jcfaber1 said:I would still use an anti-seize lubricant on the nuts.
Lisa and Tim
Cottonwood, Arizona
2015 Max S Sofitel--"The Hatbox" TV: 2013 Subaru Outback and 1994 Toyota Land Cruiser aka "the Betty"
Lisa and Tim
Cottonwood, Arizona
Lisa and Tim
Cottonwood, Arizona
hatbox said:Just picked up my max s Sofitel last week, and find that I need a torque wrench to periodically tighten my lug nuts, according to manual. They are evidently 3/4 inch. Does anyone have a recommendation on what wrench I should purchase? AutoZone fellow was a bit clueless as they did not have a 3/4... any guidance would be greatly appreciated as torque wrenches and their attachments are Greek to me.
"Hatbox" 2015 max s Sofitel, tv 2013 subaru outback
While I really don't know much about torque wrenches, except that my dealer was meticulous about checking and rechecking the amount of torque on my lugs nuts before I left.
But anyway, this is the lug wrench that is actually easy for me to use. It has two double ended sockets that includes the 3/4" socket that I needed.
What is the correct torque for the lug nuts on a 2006 (Dutchmen/Thor) T@B? I haven't been able to find that information. Mike's post about the process to change a tire/flat was really helpful. I wouldn't have thought to lower the front as much as possible before lifting the T@B. When the instructions mention using the wheel jacks, does that mean using the stabilizers or do T@Bs come with jacks and I've not found where mine is/are yet? Where would it/they be if not the stabilizers that drop down from the body?hatbox said:Hmmm...I perhaps misunderstood which are to be tightened periodically according to the manual? What do you use to tighten the lugs? The manual states "it is important to maintain proper wheel mounting torque on your lug nuts" on page 3. It says tighten the lug nuts in stages...so many ft./lb...
Exactly what are they talking about? It says to check lug nut torque before first use, and its doubtful my dealer did that, so naturally I panicked and envisioned wheels flying off as I travelled down the road. Perhaps you could explain? (I'm looking forward to the day they publish a "t@b for dummies owners manual." I appreciate your help.
Lisa and Tim
Cottonwood, Arizona
T@Buhura:
The '06 had two options for wheels, steel or alloy. This included the installed wheels and the spare. The torque specifications were different for the two wheels. the alloy wheels require 80 ft lbs while the steel requires 65 ft lbs. There is a faq on the wheels in the files section of the yahoo group.
The '06 brochure had pictures of both wheel types on the T@B (I think). The steel wheels are shown on the left and the aluminum wheels are the middle picture.
To make matters more cloudy, the T@B could have had aluminum wheels (an upgrade) on the trailer, and the spare was a steel wheel. If this is the case, they actually provided a second set of lug nuts for each type of wheel (that had a different bolt profile). On the spare,the alloy wheels had raised circles on the rim (in between the wheel mounting holes) while the steel wheels did not. If you have steels spare, they provided a separate spherical set of bolts to attach the spare to the axle. The third image is from the original manual for my '06, and the last picture shows the raised circles on the rim of the spare (the one on the left) vs the steel rim spare.
Clear as mud right? You asked, not me.
For what it's worth, I torque my wheels (I have the aluminum rim in the second picture) to 80 ft lbs and pray that I don't need to use the spare (only happened once for one day) since it is the steel rim (and I don't have the spherical bolts that were in theory provided when the trailer was purchased).
Hope that helps.
Lisa and Tim
Cottonwood, Arizona
