I am getting much closer to trading in my 320S BD for a 400 BD.
Many of you have done this.
Other than getting new awnings, what other things should I consider buying?
Any systemic 400 issues on 2024 and 2025 models I should be aware of?
I would like to know the good and bad on moving from a 320 to a 400.
Thanks for your help. This forum is one of the reasons for me to stay with NuCamp.
2021 T@b 320 S Boondock
2020 F150 2.7l V6 Turbo
Tucson, Arizona
1 ·
Thanks for you honest response. This is the information I am looking for.
Tucson, Arizona
We like not having to make up the bed every evening and the bed on the 400, while narrower, is longer and I no longer have to sleep on an angle. I can stand up comfortably in the shower. More storage means carrying less stuff in the tow vehicle. I can comfortably stand up in the kitchen area and do meal prep.
i have done a number of modifications to provide a bit more storage inside and upgraded the batteries to 400ah of LiFePo4 along with a 3000w inverter. No longer lug a generator and gas can along. Solar keeps us going strong.
Not sure what our next move is. Staying with the 320 is certainly not a bad option. But I am getting weary of the lack of headroom and changing the bed over each morning. But moving up to a 400 would make things more comfortable.
If only the 360 had a usable kitchen and counter like the 320.
Kirk
Tucson, Arizona
Anyway for now, we are staying with the 320. Everyone's input did help.
Thanks
Tucson, Arizona
My opinion is that the only reasons to buy a teardrop trailer is for its size, easy towing and ability to squeeze into tight places that the bigger rigs can't. There is a large portion of the teardrop community that believe that anything bigger than the T@G is not a true teardrop. I like to think that our 320 is still a teardrop because it passes the "can you stand up straight" test, but would not try to argue that with the hardcore group. Even thought I believe that the teardrop description is about shape, not size, the 400 (and 360) have clearly jumped the shark.
edit to add that we have no plans to move away from our 2020 320S.
Don't get me wrong. I loooooove my T@b 400 and think it's an incredible camper. I love having the dinette AND the bed. I love being able to stand up in the shower. I love the huge cooking space. But, I suspect the height difference will result in very different towing experience for you unless you have a truck or good SUV. I imagine the 320 tows even better since it's much shorter. My only true complaint is life is so busy that I can't take it out camping as much as I'd like.
I've had a few issues with my T@b. The first is I'm debugging an issue that my solar is working irratically. Many 2024 T@bs were shipped with wrong settings for the Lithium batteries. While I've corrected those, and it was working fine, in the last month it has started being inconsistent. I also just had the battery switch recall done because I have the Lithium package and I wonder if something was loosened. I haven't had the time to really dive into it yet and the weather has finally cooled down enough in the southern US that I don't mind hanging out in there without air conditioning as I sort through the issue. I did run into the issue of my front window leaking on me in a torrential rainstorm when it was propped open, but I see that's a common issue with that big front window and there are some things I can do to address it. The other windows work great. I'm really happy with the trailer and would buy it all over again. The quality difference between Forest River and nuCamp is night and day.
I like the bigger awning or tent idea if you like your 320. And if you're really adventurous, I've been impressed with the folks who winter camp with those little portable wood stoves.
2022 Nissan Pathfinder
Cary, North Carolina
I pull the 320 with a F150 twin turbo 2.7l V6. Plenty of power accelerating and going up hills. The only bummer is the gas milage really drops once you go above 60 MPH due to the wind resistance as you pointed out. On the interstate, I get between 13 and 14 MPG. I am sure that the 400 would drop that some more due to the increased area more then just the weight increase.
Love this forum. It really helps.
Tucson, Arizona
We are at the age where climbing over someone at night does not work.
But your modification would really be great for solo campers.
Tucson, Arizona
Our 320 has been a great experience for us. We've put on many more miles than most nuCamp owners and still have no desire to switch to a 400.
We still use the same TV, a V6 Colorado. Being a wider trailer, we can still see with the stock side view mirrors. Nothing wrong with adding towing mirrors though.
*We added an Andersen WDH because there was a significant tongue weight increase. The Chevy towing manual recommended this upgrade based on the specs.
*We also bought the side mount tubs. If the new models have that huge tub that I saw on a 360, I'd be jealous.
*Another (small) upgrade that has been awesome is a cutoff switch on the shower head. It is well documented on the forum that you WILL bump the shower control maneuvering in the bathroom and turn it on.
*We added an XPED Mega Mat sleep pad as a topper to the bed and bought full XL size fitted sheets for the bed.
There always more that I could list...
Virginia Beach, VA
@RTWCTS I'm looking into the side mount tubs, too, as more storage is always nicer. I, too, lust that bigger tub on the new nuCamps. I use an Andersen WDH and love it. I had a massive Husky WDH on my old Forest River trailer and hated, hated, hated messing with that thing. The Andersen hitch is so easy to connect and disconnect. I like how it cuts down on the hitch play and the T@b tows so nice and steady with it.
