Background:
Around 2018 nüCamp started using a Composite Style Floor construction. This design has an unknown material, black color, (plastic/resin like) 1/8 inch'ish layer, 1+ inch of white high density foam, another layer of the black stuff, then the vinyl floor covering. There is aluminum tube framing around the floor edges and at least one cross-frame member.
A couple of years ago nüCamp stated they were changing to an Azdel Floor Composite. Perhaps replacing the 'black material' with Azdel? With Azdel being lighter and maybe stronger as the 'black material' can/does break along the cross-frame bars over time.
Question:
What is today's floor composite construction cross-section?
Does anyone have from nüCamp information?
Any pictures of the floor cross-section?
'18
320 S,
pitched axle, 3020HE; PNW based
2021 -
2023 -
That high density foam in the 2023 looks much more stable that the previous Styrofoam. Wonder what the insulation difference is? Probably not much.
Hopefully, we will learn more details on actual usage . . .
a) Assume floors are now one piece (like Airstream TransCore) which eliminates the
older floor material breaking & leaking cross-member failures.
b) TransCore is said to be stronger than equal thickness plywood , , ,
so have the cross-member supports been removed?
c) TranCore has improved screw retention so has the Aluminum Tube outer frame
been eliminated.
d) What thickness is nuCamp using and what's the new R-Factor and lbs/in load rating
All stuff we may or may not learn over time.
nüCamp comment on TransCore usage in a slide-in camper review article:
nuCamp's first go at improving the floor composite . . . .
@Boathealer - - - What is the thickness of the High Density Foam ?
TransCore datasheet has an R-Factor of 1.44 for an ~ half inch thick panel.
