Bathroom door on 2021 Tab 400 BD change
I'm thinking about ripping the bathroom door vertically and hinging those two panels so that they fold and take less space when the door is open.  That would allow my dog water bowl to be in the bathroom where my dog could have free access to it and dribbles are easier to clean up.
Also, I would expect to change the existing hinges to facilitate this.  Has anyone done something like this?
I'd appreciate any feedback or experience you have with changes to that door.
    How about an accordion door?
  • AnOldURAnOldUR Member Posts: 1,696
    edited January 2025
    Great idea of keeping the dogs water bowl in the shower base. I like your idea and it made me think that some kind of a take on a pet door might also work. Something at the bottom of the existing door that hinged up and latched in place inside the bath. Our new pup, Jasper, is a sloppy eater. Keeping the food in there also would keep the mess down.
  • BinghiBinghi Member Posts: 399
    We have the same model trailer and had lots of problems keeping the hinge screws tight. Basically, that door is too heavy for the door frame and the hinges. Eventually all the hinges failed and we removed the door. We use the shower curtain for privacy and haven’t looked back.
  • MaxcampMaxcamp Member Posts: 348
    edited January 2025
    Our 2021 320 hinge screws pulled out due to factory power driver use.
    Replaced with ss piano hinge and also found the opening was built out of square.  The hinges were wobbly and underfit.
    Making your door a bifold is an interesting idea.  Does the opening have a bottom lip that a folded door will hit?
    The door seems to be a plastic composite material and does not hold screws strongly.  Soss hinges routed into door edges would do a nice job but again I'd be concerned about screw holding power.
    You'll need an astragal on interior to seal the joint and prevent shower splashing to outside.  A piece of white pvc trim ripped, glued with construction adhesive and screwed with countersunk flathead ss wood screws would work.
    Make up a test with some scrap plywood and pair of hinges to test clearances before you rip the door panel.
    Let us know what you come up with.
