A new-to-me mechanic flushed the alde system and replaced the fluid with a pink antifreeze solution. On these pages, I only read about either a yellow or a blue/green glycol. I called Truma, who said their product is a lime green but that the pink is probably fine.
The info here suggests that the type is very important, so Im confused. Do I need to have this flushed again and replaced with an Alde brand? With 27 pages of notes, is this really as complicated as it seems? Thank you if you can winnow this down for me!
Here are what they look like for color reference:
Edit: It might be just plain RV antifreeze which can also be pink and is propylene glycol but it doesn't have any corrosion inhibitors. That stuff would need to be flushed out.
Hmm that might be the European fluid but I don't know why somebody in the US would use it. It's arguably better because it is good for 5 years but it's too dangerous for Americans
This is what AI had to say:
While Star brite's antifreeze is designed for hydronic heating systems and contains corrosion inhibitors, it does not explicitly state compliance with Alde's G12++ or G13 specifications. Therefore, using antifreeze that does not meet Alde's specific recommendations may risk system performance or longevity.
To ensure optimal performance and maintain warranty coverage, it's advisable to use antifreeze products that are explicitly approved by Alde. For instance, Alde offers its own brand of antifreeze, such as the Alde Premium G13 Antifreeze, which is pre-mixed and formulated specifically for their systems.
2022 Ford F350 Tremor | 2022 Cirrus 620
Ethane-1,2-diol is ethylene glycol.
