On the 2019 TAB400 (and maybe earlier models, I don't know) there is a very nice blue LED light that activates when the entry door step is deployed. It shines downward and gives just enough light to see the step but not enough to illuminate the entire campground. However, There is also a very bright white light that shines upward at the same time. It is not bright enough to illuminate the keyhole, but it is bright enough to annoy people parked next to you. Is that supposed to be that way? I thought my light fixture might be a bit loose but it appears to be firmly fixed in place. Has anyone else noticed this?
0 ·
I tried that while on the road. All I had was yellow electrical tape and that greatly decreased the glare. I'll try with blue electrical tape now that I'm home again but I have doubts that tape will withstand road travel for very long. I guess those Italians had some purpose in mind for having a white light shining up at you. I don't think it is working. I'm going to see if the light fixture can be removed enough to get to the back of the unit. Some tape on the inside might last.
St Catharines, ON
No sweat. There are lots of things I remember distinctly that apparently never happened.
PNW
PNW
If you decide to add a step light, you may want to consider a motion sensor light unit.
https://tab-rv.vanillacommunity.com/discussion/17065/motion-sensor-step-light
