We took our new camper on it's maiden trip over the weekend. The first night was a harvest host stay at a brewery (Brewdog in Columbus - quite good if you are in the area). The battery was fully charged, and the alde system was set to 72 degrees on propane. The system shut down at around 5:30 AM because the battery got too low. Shouldn't the battery be able to handle that system over one night? It did get down to around 37 at night.
2023 T@B 400 Boondock
0 ·
We keep our frige set to about 5 on the dial and it uses about 35Amps of electricity. If you ran the 1200W inverter much, it probably drained a good deal of the rest of your battery capacity. Combined with lights, fans, etc. is how I imagine you got drained down.
As @pthomas745 mentioned, almost everyone has that 'bad night' and learns from it. Welcome to the club!
Virginia Beach, VA
Virginia Beach, VA
13.6V = 100%
13.4V = 99%
13.3V = 90%
13.2V = 70%
13.1V = 40%
13.0V = 30%
12.9V = 20%
12.8V = 17%
12.5V = 14%
12.0V = 9%
I had a shunt installed but still use this cheat sheet!
Sold 2023 Tab 400
Sold 2018 T@B 320S
2021 T@b CS-S
2022 T@b 400
2021 Chevy Colorado
2021 Toyota Tundra
CO Rocky Mt's, Coast of ME
For what it is worth I have added items to my 2023 which many also consider adding...DC-DC converter, 2nd solar controller for portable panels, smart shunt each outlined in bold red. For the DC-DC note the change to the electric brake power.
Jericho, VT
"For what it is worth I have added items to my 2023 which many also consider adding...DC-DC converter, 2nd solar controller for portable panels, smart shunt each outlined in bold red. For the DC-DC note the change to the electric brake power. "
I an unable to make out the fine print on you improvements.
Thank you, John B.
