PXLated, try finding a braided wire that will take the abuse of the hood opening many times, put the appropriate sized connectors to either fit under an existing bolt or screw and make fire the screw or bolt doesn't have any paint under it.PXLated said:Verna - The Jeeps are noted for their durable, galvanized steel body panels - rarely rust. The hinges are the only thing that's aluminum. I may try a jumper to the hood.
I wouldn't say everyone needs one. I bought mine to help me able to work remotely. Will you have to do a little trial and error and problem solving to get it to work? Possibly. If you aren't interested in that, this probably isn't the device for you.vito said:Reading all of the above comments convinces me to NOT buy a cell phone booster at this time. I remember in the old days when I had a rooftop RV antenna for (non-digital) TV broadcast signals. Wanting to pick up a somewhat distant local station (so that I could watch certain NFL games not being broadcast on the network station) I tried a higher, larger antenna on my roof. That was not a solution so I tried a "booster" device, which seemed to do absolutely nothing. Makes me skeptical about a cell phone booster as well.
Oh yeah, Verna knows very well what corrosion does to copper. It creates an "open".jkjenn said:
