I wanted to start a discussion for owners of the Ultimate Toy teardrop to introduce ourselves and share. Please also share your thoughts on stuff like mods, mantenance, camping excursions, or anything else related to this unique nuCamp product. Non-owners are also welcome to participate!
Ultimate Toys Teardrop
Jeep Grand Cherokee
Dallas, TX Area
0 ·
Jeep Grand Cherokee
Dallas, TX Area
Volvo XC-40
SF Bay Area, California
Volvo XC-40
Volvo XC-40
Jeep Grand Cherokee
Dallas, TX Area
Jeep Grand Cherokee
Dallas, TX Area
As a T@B CS owner for 14 years, for us, this was the ultimate upgrade of a very unique camper. We're so glad we got ours...
Volvo XC-40
Working through the rabbit hole of the forums - I've noted some mentions of the lack of a UT manual, and as I bought this remotely, I didn't get a proper tour. Was curious if the 2022 320 CS-S was a close enough reference? Am noting the differences with the heating system and the Bosch Instant Water heater, etc.
Thanks in advance.
Jeep Grand Cherokee
Dallas, TX Area
There is no flush tank. The toilet operates with the water system pressure.
Volvo XC-40
Volvo XC-40
Been there - done that...
https://www.amazon.com/dp/B075NM3NPD?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
Volvo XC-40
Volvo XC-40
The new one did seem very tight and had to be worked straight in. Not letting one side to seat before the opposite side is started wouldn't work.
The valve stem never lined up very well on any of mine. It seemed too short to be accessible so I added a short metal extension.
I still have one original and am pretty sure they are the very same manufacturer.
Volvo XC-40
Volvo XC-40
Volvo XC-40
Valve stem extensions:
https://www.amazon.com/dp/B08BVVJCFQ?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
Jeep Grand Cherokee
Dallas, TX Area
Volvo XC-40
Jeep Grand Cherokee
Dallas, TX Area
Volvo XC-40
Jeep Grand Cherokee
Dallas, TX Area
Volvo XC-40
Volvo XC-40
They have to be worked straight in. Not letting one side get too far in before the opposite side is started won't work. I sometimes use a small rubber mallet at the edge but it can dent the metal. I usually use my fist. Hold it nice and flat in the correct position and work the clips into the rim a little bit at a time ( 1/8 to 1/4 inch) tapping around the outer edge.
If you bend the clips to make it easier to install it will also bounce off that much easier. I actually bent the corners out a bit on a third of the clips to give them more bite on the rim.
