2023 TAB 400 adding wireless backup camera - easy power
Added a wireless backup camera today.  I powered it off the license plate light, but I found that access to that power was pretty easy.   I removed the panel at the very rear of the bed, and there is a through-body hole with the wiring for the license light easily accessible.   I removed the sealant from the hole so I could bring in the power for the camera in thru the same hole.  Once inside, there are connectors within inches of the access hole.
I removing the 5 or 6 screws from the bottom of the plastic shell outside, and that gave me enough room to mount the camera and run the power into the hole.  After running the new power cord thru the hole, I re-sealed it with silicone.
I used this camera/monitor from Amazon (https://www.amazon.com/dp/B078PDH6Z8).  It has a very clear picture and synced up immediately.   I have not had it on the road yet but zero issues with it so far.
2023 TAB 400, towed by 2001 Ford f-150 Supercrew XLT 5.6 liter v8
  • subkronsubkron Member Posts: 177
    Do headlights at night washout the display (override the4 camera)?
    2022 T@B 400 Boondock
    South Jersey
    Nice looking install job, vey clean.
  • HedCountHedCount Member Posts: 47
    subkron, I hadnt thought about it but I'm sure at night headlights from behind will impair the image.  But that shouldnt be a problem backing into a spot.  That's when the image really counts.  The night vision of the image seems pretty good for backing at night
  • AndreOAndreO Member Posts: 73
    On my 400 its just under the starlight window. It won't matter if you just use it as a backup camera but as an observation camera while driving yes it will white-out from both vehical lights and sun rise/set. The other point to note depending on camera is they are typically manufactured to look down so a low mounting point makes cars (trees etc.) appear farther away than they actually are.
    AndreO
    Ontario, Canada
    2018 Tab 400
    Ford F150 2.7 Lariat
    On mine I mounted it on the roof fan when I replaced the roof air with a MAX-AIR. I also attached a piece of nylon to act as an umbrella to protect the camera lens from to much sunlight. I put a switch onto the inside frame to power the camera and if I remember to turn on that switch it works great. I can also angle the hood to keep most sunlight out of the camera. Art
    2019 TaB 320 S Boondock Edge
  • AnOldURAnOldUR Member Posts: 1,524
    @gulfarea, it looks like you have the same Garmin camera system that I have. Originally I attach the BC30 to the fan housing. There was easy access to electric there. Worked well, but when I installed a MaxxFan it required a new method. I ended up putting the BC30 down by the license plate and put a BC40 up on the roof with a suction cup mount.
    The problem with the BC40 is its limited range. I tried using one down by the license plate, but the signal was intermittent at that distance. Swapping them around has worked well. I can have the BC30 on full time while driving to keep an eye on tailgaters. The BC40 can be switched to for a different perspective or to check that the gear loaded on the back of the T@B is secure.
    Great idea for putting a hood over the BC30 for glare. I'm going to give that a try.
    @AnOldUR I read your posts a lot, keep them comming! I put the transmitter up in the MAX-AIR fan area as this gets the signal into my Jeep very well.  In this photo you can see where I mounted the on-off switch and fuse holder in the bottom of the MAX fan. Art
  • Firebird_WS6Firebird_WS6 Member Posts: 9
    edited July 2023
    @AnOldUR What suction cup mount did you use for your BC40? I have one mounted on my license plate, but the signal is not strong enough as you noted. I'd like to try it in the location you have it. Is it still working ok for you in that higher location? Do you have concerns about the suction cup coming off and losing the camera?
    2018 T@B 320S / 2017 Subaru Outback / Seattle, WA
    edited July 2023
    By now I probably have a reputation (good or bad) for doing things that others wouldn't consider. This may fit into that category. There's a tab on the back of the camera that I'm assuming is for manufacturing purposes. I ground that off to create a flat surface then epoxied it to a suction mount. I think it was a Garmin mount, but could have been left over from something else.
    So far the mount has held well even in hard rain, but I've tied a safety string to it so I won't lose it if the suction fails.
    The only drawback is that changing batteries is more challenging.
  • GordoBGordoB Member Posts: 3
    You referred to the outside plastic shell.....in addition to the screws, was your panel glued as well?  Mine seems to be glued onto the rest of the unit.  I am reluctant to peel off.
    @GordoB Yes, it had some mastic like adhesive on the lower section.   I didnt remove the whole plastic panel, just the lower section enough to get my arm up to the shelf above the license plate so I could tighten the nuts holding the camera.  It wasnt real hard.  The adhesive stayed pretty sticky, but it might need to get it warm to get it to adhere well when you close it back up.
    Thanks @HedCount !  I am struggling a bit.  I am trying to fish the camera wire through along the same path that the license plate lights go through the trailer wall.  Really having a difficult time doing this.  Did you drill additional holes to pass your camera wire through to the connection area?  I have attached 3 pics: one is the hole I drilled on the back shelf where I intend to mount the camera.  Its the wiring that I am struggling with.  Any advice?
    @GordoB You are working in the same place I did.  I think I had to force a philips screwdriver thue the hole first to make a hole past the sealant that is there.  I caulked it back up after getting my wire through.
    So you used the same path as the license plate light wires.....no new holes?
    Yes.   Tapped power INSIDE the trailer in those wires for the license plate lamp.  Note you will have to have your tow vehicle power on and attached to the trailer to use that power
