Finally!! A real trash can!!
Found this trash can on Amazon after careful measure and LOTS of searching - https://www.amazon.com/dp/B0DFCDDV5K
Clipped off the little side hooks and mounted a pair of heavy picture hangers:
Mounted the companion hangers (inserting) onto the trash can:
I made sure that the weight of the trash can rested mostly on the lip of the door's inset so that there would be less stress on the picture hanger-thingies.  Fits perfectly into the recess, even with the swivel top!  Just enough to be bigger, but not too much of an intrusion inside or out.
The swivel part (by accident) rubs a bit on the door plastic, but allows it to be propped open during use.  If it becomes an issue, I'll just put some 1/8" inserts behind one or the other pair of mounts........
The top lid insert pinches a trash bag nicely to hold it in place!  This one is a THREE thumbs up!
  • AnOldURAnOldUR Member Posts: 1,604
    How long before you destroy your screen door? 🤭
  • donmontalvodonmontalvo Member Posts: 154
    edited May 7
    The old trash can also overlaps the screen door line. I use the original trash can to hold my plastic grocery bags (I double up at Wallymart). Then I hang the bag from the door "knob", so I never forget to get rid of it. I check the bag for any pinholes, if there are any, I double up. Never had a spill, always easy peasy.
    Don Montalvo | Retired Veteran | Full Time Snowbird
    2024 nuCamp T@b 320S Boondock Black Canyon (480W solar|200ah LiFePO4|1200W inverter)
    2021 Jeep Wrangler Unlimited Rubicon (130W solar|100ah LiFePO4|DCDC|1000W inverter)
  • Gomers2Gomers2 Member Posts: 84
    Nice job! I just did something very similar because I also could not stand that trash can. I built one with a slight taper so it doesn't interfere with the fridge. And the lid stays open so it's a lot more useful while cooking.
  • boathealerboathealer Member Posts: 47
    Nicely done!!
  • marchulemarchule Member Posts: 47
    Purchased the gray Amazon trash can.  Did not mount it on the door but simply used as a free-standing trash can to see how well it would work.  The swivel lid limited how much trash could be placed inside.  The lip around the top was not "deep" enough to secure it to the can.  It took too long (for me) to stretch a trash liner around the rim of the can.  Returned it to Amazon.  Don't know why, but I have really struggled finding a great solution for handling "inside" trash.  Having trash on the door is a nuisance and a potential fly-magnet in the summer when the door is open.
    2018 320S / KIA Sorento 3.5 V6  - 2022 400 Boondock / KIA Telluride 3.8 V6  -  Utah
  • SLJSLJ Member Posts: 618
    Looks like it sticks out further. I would be worried it will break the screen if you forget to open it before shutting the door.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2023 Ford Maverick XLT
    The Finger Lakes of New York
    The max depth is about the same as the original. Just not rounded so it has better volume. The door hasn't really been an issue. Not too likely to close the door from the outside and not see the screen, but if you did it's very flexible and just goes back into shape.
    Check it as being "not round" will definitely push more screen area than the original door trash can does. "Not too likely to close the door from the outside and not see the screen". From past experience there is a 100% chance that will happen at some point no matter how careful you are.
    The door/screen design on the newer T@Bs is the thing I dislike most. They should have stuck with a standard door and swing out screen door combination.
  • MaxcampMaxcamp Member Posts: 330
    Great mod, thank you @boathealer.
    While I would not advocate closing on screen deliberately, the pleated screen easily deflects and should be fine- see pic.
  • kdcampergirlkdcampergirl Member Posts: 22
    I’m looking into doing this. Great mod! Where do you get the picture hangers?
    Worth noting fridge door doesn't open fully unless open tab door.  Bottom drawer  obstructed likewise.
    After this trip will shift to middle or swap can with extinguisher.  For now using doublestick tape and did not cut off plastic door tabs.
  • HoriganHorigan Member Posts: 767
    edited June 23
    Rich
    2019 T@b 400
    Bellingham WA
    Thank you!! Did you use the plastic screws? Not sure what would hold the fitting on the trash can end.
    edited June 24
    I haven't installed mine yet.  If I find just thin sheet metal in the door, I may go with pop rivets, as well has having the can rest on the lower ledge of the door.  If I find the door inside to be more solid, I'll use wood screws.
    For the can side I'll use a short bolt and nut.
    Rich
    2019 T@b 400
    Bellingham WA
  • RVMikeRVMike Member Posts: 30
    This is how I mounted the trash can.  I did not want to cut the tabs off of the T@B door, so I cut some holes in the trash can.  To cut the holes, I heated up a utility knife blade and melted a square hole.  If the holes were in the wrong place, I could just buy another trash can.
    The biggest downside of this trash can, in my opinion, is it blocks the drawer underneath the fridge when the T@B door is closed. Other, not problems:  The lid of the trash can does not fit in this configuration, but this is not a problem for us. And, yes, the trash can interferers with the screen door, but, again not a problem for us.
    I have kept the original "trash can," the lid and lid spacers and will provide to the next owners of this rig when the time comes.
    Mike
    Mike and Priscilla, White Salmon, WA
    2020 T@B 320 S Boondock Edge, 2020 Subaru Outback
  • rfuss928rfuss928 Member Posts: 1,106
    edited July 13
    RVMike
    Clever.
    A little hot knife mod on the lid might solve the lid fit problem?
