We just upgraded from a 2016 Outback to a 2024 320 Black Canyon and are having difficulty keeping the battery charged while boondocking. The new rig has a single 100ah Battle Born with either 190 or 380 watts on the roof (I cannot get a straight answer out of NuCamp on the panel size, so if anyone knows for sure, please pass it on). We love the upgrade, but even with conservative power use, the battery has run down to zero twice -- once last Christmas when sunlight was meager at best, but again last week after three sunny days. I'm pretty sure we're just using more power than we're taking in, thanks largely to the 12v fridge. I think we need more charging capacity, so I plan to buy a portable panel, probably around 200w. Here are my questions: 1. Do you solar warriors agree that I need more charging rather than another battery? 2. Can I run the additional solar charging through our existing Victron MPPT 100/30 controller? 3. Would I gain anything by installing a second 100ah battery? Thanks a million.
0 ·
Renogy Wanderer Li 30A 12V PWM Negative Ground Solar Charge Controller Solar Panel Regulator w/ Temp Sensor Function Fit for Lithium, Sealed, Gel, and Flooded Batteries, Wanderer Li 30A https://a.co/d/gDBe15c
We like the portable option because you can get it into the sun when the trailer is parked in the shade.
However I do agree with @HappyWanderer that you need to check your settings and set up before you buy anything else. You said you were out for three days that had some decent sun and still ran out of power? That's not my experience. We Crank that fridge and have plenty of power on sunny day trips. This week we were out for a 48 hour trip that was very cloudy the entire time, lots of rain and set up in a heavily shaded site. After 48 hours we were down to about 10% left. That was with very conservative usage (fridge on level 3, then level 2 and minimal need for light at this time of year) and virtually no charging. You're not just experiencing a low state of charge number, but are in fact out of power?
For a quick reference, solar panels provide about 17.25 watts of power per square foot so, if you measure your panels, you can calculate their capacity pretty easily.
Another point of reference. We camp off-grid almost exclusively. I always run the 12v refrigerator, lights, pumps, etc. On average, I use about 22 amp/hours overnight. I have a 105 watt panel on my roof and a 200 watt suitcase. With decent sun, I get back to100% by mid afternoon.
I love the rooftop panel, but we camp in the woods a lot so my rooftop unit is often in the shade.
The way to tell if you need more battery or more solar is check when the battery gets fully charged on a sunny day. If you reach 100% sooner in the day, like late morning/early afternoon, then you need more battery capacity. If it's taking longer to charge to 100%, then you need more charging capacity.
In general though, you want to have the same, or similar, numerical value between battery capacity in Ah and the solar capacity in W. You're 100 vs 380, so that would imply you could use more battery capacity
Happy Wanderer, I finally found the battery settings and changed them to the recommended levels. None appeared to be too far out of whack, but we'll see over the next few days whether the charging improves. My Black Canyon has two wide racing-stripe panels, each about 12 inches by 120, so roughly 20 sf of cells. If Basil48912 is correct, that's about 255w. Which still seems like it should be plenty, but I will probably add 200w more. I had seen NuCamp tout their solar system as plug and play, but it sounds like a second, smaller charger would be smart.
Gomers2, the first time we ran to zero was right around Christmas, and we were camped in a shady spot in the SoCal desert, so clearly we weren't getting much charging. The second time was just last week in sunny Colorado, though again we parked in the shade. Both times, the battery dropped a little the first day, a little more the second, and then hit zero on the morning of the third.
Cherokee, if I could have found a 3-way to replace the one in our 2016 Outback, I would still have that rig. But apparently no one is making 2cf 3-ways any more. Hence the new trailer and its new power demands.
Marceline, yes, we cool it down for a day or more on shore power.
Wish me luck....
Are you using the Victron Connect app to monitor solar power production (Victron controller) and to monitor net power in/out of your battery (SmartShunt)?
Came with 2x180W solar panels (flexible, on curved roof) and a 100ah LiFePO4 heated Battle Born battery.
PS, the Bugout 130W solar panel on my Jeep keeps my Jeep's 100ah LiFePO4 battery topped off when I'm not traveling...the alternator keeps it topped off while driving.
2024 nuCamp T@b 320S Boondock Black Canyon (480W solar|200ah LiFePO4|1200W inverter)
2021 Jeep Wrangler Unlimited Rubicon (130W solar|100ah LiFePO4|DCDC|1000W inverter)
https://revkit.com/donmontalvo/ | https://donmontalvo.com
But the shunt reading confused me. Around noon yesterday it said "consumed Ah" was 0Ah, even though the trailer had been "boondockiong" in my driveway for four days, and a few days before it read -25Ah. This morning at 6:30 a.m. I checked again and overnight the battery had dropped to 13.07v and consumed Ah was -27Ah.
Does that seem normal? I can see how the solar charge varies, but how can I tell what my usage is, and more specifically, what I can do to reduce that usage?
One last thing. Don, after reading about your inverter, I realized that I may have a similar power source. My new Tacoma hybrid has a 2400w inverter built in, with an outlet in the bed. It only works when the engine is running, but it seems like I could turn on the engine and power up my trailer battery directly off the inverter rather than through the engine's alternator. What do you think?
For my 2021 JLUR (almost bought a Tacoma!), before I decided to get my 320S, I had Main Line Overland build an off grid kit in the JLUR. So it has a 1000W inverter, a 30A DCDC charger, 100ah LiFePO4, and a folding 130 Bugout solar panel. Back then I spent in my iKamper roof top tent, which had power run to it from the kit. Bought the 320S, sold the iKamper TTT, and the off grid power kit is my backup.
https://donmontalvo.com/2022/03/27/main-line-overland-lifepo4-ftw/
The LiFePO4 batteries in my 320S and my JLUR get charged when I am on the road. Haven’t installed a doohicky to disconnect JLUR power when boondocking, for now I just disconnect the tow cable.
I don’t have experience with powering camper batteries through your Tacoma’s inverter. I would think a DCDC charger might be best for that?
2023 T@B 320 S Boondock
Is this correct?
