Hello, when I set my water to City Water mode and turn on the water, it immediately flows out via the overflow tube. Anyone experience this and have idea what the problem is? Thanks!
Look under the trailer and find the exact spot or drain where the water is coming from.
If you are not using a water pressure regulator on city water, you may have "tripped" the Famous Yellow Flapper valve, which you can find under the driver's side bench down near the Alde. If you are using a pressure regulator, the yellow valve may have just been left open. Look at the link posted by Yoshi that has pictures and descriptions on what to look for.
TAB 320S BD City Water overflowing
Southern Maryland
