My drivers side running light doesn't work. My right side works, but with less than full LEDs showing up. All other functions on both lights work... brakes, turn signals okay. I tested the 7 pin on the car and got a bright light from the 11:00 pin on the 7 pin. So I think that electricity is good there.
I removed the 4 screws from around the driver's side taillight on the T@B. That panel doesn't come off easy so I'm guessing that there is a sealant there. Not sure if it is the correct place to look so I've stopped for now.
I removed the 2 screws from the red lens cap, which falls off easy, but the light is snug there. Not sure what's called for, so I stopped for now.
Any suggestions on how to proceed? Thanks, Parlando
https://www.amazon.com/Kaper-II-L15-0021-Trailer-Light/dp/B0113XPTIK
Not sure how to test for a bad running light situation - when other functions are working. Maybe someone can chime in. However, I do know that with older trailers like ours, the LED's need to be replaced because they start going out. Sorry I couldn't be of more help.
TV 2022 Highlander
CheeMuii 7 Way Trailer Cord Heavy Duty 8 FT Trailer Wiring Harness Kit 7 Pin Trailer Plug Inline Wire Harness Cable for Trailers RVs Campers
A heat gun should weaken the sealant so the old light assembly can be removed.
- 2 - Many folks have been able to pop the LED circuit board out of the housing.
If the LED assembly is bad I'd again attempt to get the Board out first (see #3)
- 3 - It may not be possible to purchase the L15-0021. Possible other brand units don't
match the L15 size so full replacement of the assembly will be needed. There are a
couple of forum threads on installing a different brand light.
- 4 - Your observation that the tow vehicle or trailer 7-pin may impact brightness is
interesting. Poor connects causes high contact resistance which lowers the voltage
at the final wire end.
Troubleshooting Ideas:
- A - Use the trailer battery to fully test the tail light assemblies.
Run a wire from the Battery Positive to the 7-pin contacts for L/R Turn and the
running/tail lights One-at-a-Time.
Observe LEDs (dark shade might be helpful) can you see if the correct number of LEDs are on.
- B - If 'A' results are poor, move the battery jumper wire to the Junction Box location.
If results are Good then 7-pin connector or cable has issues.
If results are still poor . . . time to consider replacing LED assembly.
Test Overview:
Tail Light Assembly Theory of Operation:
https://tab-rv.vanillacommunity.com/discussion/comment/125841#Comment_125841
If I am understanding it correctly, you are experiencing some individual LEDs in the taillight on the driver's side being burned out. It seems to me that the solution is just to replace the taillights. I doubt that the 7-way cord or its connection is the issue (at least not the primary issue.) @MuttonChops's suggestion to use the heat gun to remove the caulking is a good one. Hopefully, that will allow you to remove the lights and easily replace them.
In the past, others, including me (in Oct 2022), have had issues with some of the LEDs burning out. I replaced mine with the same taillights as @Tabaz (https://www.superbrightleds.com/catalogsearch/result/?q=TLS-R17HF-R-K (4” round). I took a photo of the original light as the LEDs were starting to fail, so I am posting that here if it is of any value to others. I have a video of the three defective LEDs intermittently flickering on and off, but I cannot figure out a way to attach it here. Before I replaced the taillights, additional LEDs were beginning to fail, so replacement of both taillights made sense. I am also attaching a couple additional photos to show the wiring connections and what the taillight looks like when illuminated.
If that does not work out, take a look at the below discussion. The lights referenced by @Cyclonic at the beginning of the discussion are currently available on eTrailer.com and might work. You can download @Cyclonic's installation PDF to see photos of the lights. @Cyclonic described them as being 4" lights, but the diameter provided by eTrailer is 4 5/16", so you will need to confirm that will work.
https://tab-rv.vanillacommunity.com/discussion/comment/134724#Comment_134724
The L15-0021 has 18-diodes; 5-wired for running and 13-wired for stop/turn (which also powers the running 5). So there are Two electrical Blocks of LEDs, if the trailer has a ground wire issue all 5 or all 13 LEDs would not function. Having only 3 bad indicates the individual LEDs have failed**.
Would be fun to know if the 3 bad sites are on the Running light or Stop/Turn block . . or was it a mix.
Short answer, agree your extra ground wire test would eliminate a trailer wiring ground issue.
Overall, I've become confused as the various 'tests' seem to have differing LED status results. The PDF file results for the "good bright" right side (passenger) do not track with the L15-0021 specification. Your trailer might not have L15 assemblies or could have failing units in both driver & passenger side.
If my rig . . . I would purchase at least one new (equal diameter) LED assembly, connect it to the trailer and confirm you get correct (to LED specification if known) running, stop & turn LED count and brightness. Or equal to eye when wired to the Driver and Passenger trailer wires.
Expect you will find both the current trailer LED assemblies are failing and/or have running & turn/stop wiring errors.
Your PDF reported results:
First thing to check . . .
Is the Alde 120VAC power cord plugged into the Alde compartment outlet?
It is very common for the plug to vibrate out of the outlet overtime, many of us have strapped it in place.
