i am using a victron MPPT 75|15 and. keep blowing it's 30 amp fuse. I'm not sure what to look at. I have a 30 foot 10 gauge cable, but the fuse is blowing before I even connect to the solar panels. As soon as I plug it into the connector, the fuse blows.
                T@B 360 Black Canyon, 2021 Jeep Grand Cherokee V6, Maryland
(previous 2018, T@B 320 Outback)
0 ·
And the Controller fuse is blowing when the 30-foot extension cable ONLY is plugged in, Yes?
That sounds like a 30-foot extension cable short. Even if your SAE Port and solar panel polarity are wrong the Controller fuse would not fail when a fully open extension cable was attached.
Now I have spent two days trying to get their performance up to par. At first I was getting 50 or 60 watts, so I made sure to set the controller with all the key settings from the Battleborn site that match those on the camper's onboard controller. After doing that, my performance went down to 30 watts. I returned the panels to default and they spiked back up to 135 watts. I used the LifePO preset which are nearly the same as Battleborn and the performance went back down to 100 watts.
Inconceivable!
200 watt panels. Clear blue sky. full southern sun exposure. Battery at 73%. That's further off theoretical 200 watt spec than I would have expected. settings in the controller seem impenetrably complex, fussy, and difficult to find. Battleborn site is simplistic and vague. every time I try to manually configure settings, performance drops to 30 watts and stays there. (full sunny day at 2:00 in the afternoon.)
Any suggestions?
Camper: nuCamp T@B 320S BBC 480W solar and 200ah LiFePO4
TV: JLUR | Tow Package | 100ah LiFePO4 | 200W Solar | DCtoDC
https://revkit.com/donmontalvo/ | https://donmontalvo.com
