TAB 360 Solar is Weak
I've been tracking down my solar situation as it deals with the recall of Sunflare panels. I think I am caught up in that and am waiting for approval of my claim.
I've been researching a possible upgrade of my panels when I have them replaced. In my research, I have come to some conclusions, and I am curious of others agree with what my conclusions.
1) the configuration of long thin panels from front to back is cool looking, but not a good pattern for real life. The only time that the rear-facing panels get good exposure is either in the morning when the rear of the camper if faced east or in the evening when it is facing west. During morning and evening, the rooftop doesn't get good exposure. Good exposure on the roof starts around midday. At midday the rear portion of the panels are operating sub optimally and averaging the roof panels down.
2) The panels are wired in series. This can be good in optimal situations, but when a part of any panel is shaded, then all the panels behind them have their amperage reduced to the lower number of the shady area. This is somewhat offset by the increase in voltage of being in series, but there are some complexities that make this tradeoff problematic. If you had more individual panels wired in parallel or seres/parallel, this problem would be reduced.
3) The panels installed don't seem to have bypass diodes. The purpose of bypass diodes is to reduce the effect of shade on panels wired in series.  These would reduce the impact of everything above.
It would be much better to have the two long-thin panels made into four panels. There should be two wired in series on the roof and two on the rear wired separately in series. Those two series-pairs should be then wired to the controller in parallel.
The battery is insanely inaccessible. In order to access it you will need to remove the entire belly pan. To remove the belly pan you will need to remove all four jacks AND the axle. YES. The belly pan is above the axle and the mounts for the jacks. Otherwise you could cut a hole in the plastic and then somehow close it back up.
There isn't an LCD display in the camper to tell you what is happening with the battery and solar. You are required to look at your phone to see the status. I don't want to look at my phone when I am camping. I'd also like to add a Victron MPPT Control Display.
I am afraid that with what I have, I won't be able to power my refrigerator with solar, particularly if I'm not in full sun. I'm looking at replacing the current panels  Many of the panels are about 40"- 45", so we can fit two of those on each side as well as squeezing a 50 or 100 watt panel between the back window and roof vent. I've been trying to find panels with bypass diodes that will fit to the left or right of the rear window and roof vent. We've got about 22 inches to the left and right of the window (actually exactly 24.5, but I wouldn't want to go all the way to the edge) and I can't find high-end panels that will fit in that width. I haven't seen any that will fit in that width that also have bypass diodes.
T@B 360 Black Canyon, 2021 Jeep Grand Cherokee V6, Maryland
(previous 2018, T@B 320 Outback)
  • elbolilloelbolillo Member Posts: 525
    In the long run you would be better off investing in a portable suitcase panel to help keep your battery topped off. An external port connected to its own MPPT charger would allow you to have an external panel that can be positioned for optimal solar charging.
    As for having to look at your phone, I really don't see that as an issue.
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,013
    I guess I’m  kind of surprised that more owners have not mounted regular solar panels.  They’re probably a risk with hail, but it seems like the output would be better than the flexible panels.
  • donmontalvodonmontalvo Member Posts: 154
    edited August 19
    I have come to terms with the challenges of curved solar panels. My 2024 320S BBC has 2x190W panels on its curved roof. My 100W flat portable panel kicks it's @$$ on sunny days. The 2x190W have the edge over my 100W flat panel on cloudy days.
     Can't fight the curve. ;)
    Don Montalvo | Retired | Veteran | Full Time Snowbird
    2024 nuCamp T@b 320S Boondock Black Canyon (480W solar|200ah LiFePO4|1200W inverter|EMS|SoftStart)
    2021 Jeep Wrangler Unlimited Rubicon (130W solar|100ah LiFePO4|DCDC|1000W inverter)
    I have been pretty happy with the rooftop solar.
    Last week, in hot weather, I left camper battery on with the fridge running and ran the fan (MaxxAir) on the lowest speed while I was at home for the week. The solar really did a nice job, even with a day of pretty much heavy cloud cover and I had plenty of battery left when I hit the road yesterday. I thought I would need to plug in because I knew the compressor would run a bit more with the camper nose facing due south and hotter weather.
    I don't expect a max solar yield all day because of the curve, but I also get solar longer because they are not on only one side of the camper.
    Late last summer, even at late day, (almost 5:00 PM) I was pulling in over 200w.
    I am a heavy power user (due to remote work) when I camp so I also use a portable setup that allows me to track with the sun and supplement.
  • tphaggertytphaggerty Member Posts: 62
    I have 2 renogy flexible 175w panels on my 400. They go across the roof, not down. One on the front, one on back. In series. I have never seen 350w of production, but have seen close to 300 when driving with the sun overhead.
    The renogy panels have blocking diodes and definitely work when only one panel has sun. I also use a 100w portable panel sometimes. My goal is not to fully replenish the batteries every day, but to extend the time my 300ah of lifepo batteries run to meet my time at the campsite with maybe a day to spare without having to ration my use. Seems to work out. I think the key is having enough battery capacity.
    2019 Honda Ridgeline RTL TV
    Poughquag, NY
  • ginsbujginsbuj Member Posts: 53
    360 parked in total shade for four days. Frig stayed cold and my batteries still at a quarter charge. I added a second 100 Battleborn just so the frig didn't deplete the juice. So far this 360 is working flawlessly. Love new camp
    TAB 360 Black Canyon
  • TrailpixieTrailpixie Member Posts: 189
    So it sounds like the TAB 360 isn't self-sustaining with its solar panels and refrigerator while boondocking. It may ran two or four days, but depending on the heat and sun and other energy use, you will run out if you only have on-board solar.
    For me, spending lots of time in partial shade, I am definitely out of luck. With my TAB 320 and top-mounted parallel wired solar, I seemed to do better.
    My fridge ran on battery for a week while sitting at home recently in full hot sun. With partial shade at Yellowstine last year. I spent a long weekend and had plenty of battery left, too.
    I am wondering if you are leaving your inverter on all of the time and that is leading to faster battery drain?
