Has anyone ever had a problem with their Lagun table getting stuck? If so, what did you do? The pedestal on mine gets stuck sliding on to both the interior and exterior mounts. It won’t slide down more than a few inches. The handle is loose. I tried cleaning out the grooves. Does it need to lubricated with something.
Thanks in advance,
Laura
Laura
2017 T@B 320 S / 2017 Jeep Grand Cherokee
Santa Fe, NM
3 nights and counting...
0 ·
Santa Fe, NM
How many folks have "overtightened" the handle and found it so seized you could not back it off with tools, had to saw through the bolt and replace handle, as I am doing?
It must not be uncommon!
Interestingly, the Panther RV product description reads:
Lagun 06334 OEM Replacement Table Leg Handle
This is an OEM Replacement Plastic Handle in the event that your original handle becomes over-tightened and stuck in a locked position. It is designed to compress the table leg or arm, which features a channel, allowing it to tighten around the inserted bracket or leg. This secure compression ensures the table remains stable and does not move.
$30 https://pantherrvproducts.com/06334========The Lagun USA product description reads:
Handle Replacement Instructions:
https://lagunusa.com/product/handle-kit-plastic/
$33. Or buy the entire arm with two handles for $73.
I purchased and returned 'normal' M8x1.25 thread carriage bolts and have to buy this expensive part instead.
. The carriage bolts Lagun uses have a much larger square boss under the head than appears normal. The square recess in the aluminum arm is creatively but poorly 'machined' by Lagun by drilling four holes rather than using a broaching tool. For some this will lead to stripping out the bolt head.
All in all this is a disappointing product. The threads appear to have galled and cannot be backed off. The force needed instead spins the brass threaded insert around which the plastic handle is molded.
I've only had to deal with the plastic bushing wear.
( now travel with Lagun table fully supported or removed from the post.)
