Sticky Lagun Table
PoodleMayhemPoodleMayhem Member Posts: 11
Has anyone ever had a problem with their Lagun table getting stuck?  If so, what did you do?  The pedestal on mine gets stuck sliding on to both the interior and exterior mounts. It won’t slide down more than a few inches. The handle is loose.  I tried cleaning out the grooves.  Does it need to lubricated with something.
Thanks in advance,
Laura
Laura
2017 T@B 320 S / 2017 Jeep Grand Cherokee
Santa Fe, NM
3 nights and counting...
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,012
    I suppose it is possible that they did not cut the groove wide enough to allow it to drop all the way - especially since you are having problems with both the inside and outside mounts.  I would see if you can get a replacement pedestal.  You can try lubricating it with a silicone spray.
  • BrianZBrianZ Member Posts: 1,767
    Maybe a dry silicone spray or a powdered graphite lubricant like they recommend for the windows (or was it the screen door track?).
  • PoodleMayhemPoodleMayhem Member Posts: 11
    I tried graphite (because I happened to have some).  A little improvement, but still sticky.  I’ll try the silicone spray next.  Thanks for the suggestions!
    Laura
    Santa Fe, NM
    edited June 2019
    I believe 3M, WD40, and 3-In-One all make a dry lube type of silicone spray.  3-In-One labels one as an RV window track lubricant.  Search on "silicone dry lube".
  • GuinnessGGuinnessG Member Posts: 2
    filling the fresh water tank
  • MaxcampMaxcamp Member Posts: 335
    There are numerous threads about lagun table woes.
    How many folks have "overtightened" the handle and found it so seized you could not back it off with tools, had to saw through the bolt and replace handle, as I am doing?
    It must not be uncommon!
    Interestingly, the Panther RV product description reads:
    Lagun 06334 OEM Replacement Table Leg Handle
    This is an OEM Replacement Plastic Handle in the event that your original handle becomes over-tightened and stuck in a locked position. It is designed to compress the table leg or arm, which features a channel, allowing it to tighten around the inserted bracket or leg. This secure compression ensures the table remains stable and does not move.
    $30 https://pantherrvproducts.com/06334
    The Lagun USA product description reads:
    Handle Replacement Instructions:
    • Use a rag to protect the arm/leg & secure in a vice or similar device.
    • Using a hacksaw or a similar tool, use slow even strokes to cut the handle or bolt
    • Tap out the old bolt
    • Remove end caps (if applicable)
    • Install a wooden block inside the end of the leg/arm.  Make sure the block is relatively tight, so the aluminum does not get compressed.  The block should be right next to the hole the bolt is going to be re-inserted into.
      • This MUST be done so you do not cause the aluminum to become distorted, thereby ruining the function of the leg/arm.
    • Install new bolt, washer and handle
      • Loctite anti-seize for stainless steel may be applied
    • Remove wooden block
    • Install end caps (if applicable)
    https://lagunusa.com/product/handle-kit-plastic/
    $33.  Or buy the entire arm with two handles for $73.
    I purchased and returned 'normal' M8x1.25 thread carriage bolts and have to buy this expensive part instead..  The carriage bolts Lagun uses have a much larger square boss under the head than appears normal.  The square recess in the aluminum arm is creatively but poorly 'machined' by Lagun by drilling four holes rather than using a broaching tool.  For some this will lead to stripping out the bolt head.
    All in all this is a disappointing product.  The threads appear to have galled and cannot be backed off.  The force needed instead spins the brass threaded insert around which the plastic handle is molded.
  • MuttonChopsMuttonChops Member Posts: 1,851
    That's a new to me failure issue.
    I've only had to deal with the plastic bushing wear.
    ( now travel with Lagun table fully supported or removed from the post.)
  • pthomas745pthomas745 Administrator, Moderator Posts: 4,322
    In this thread there is a picture and description of an owner who simply replaced these "ratchets" with simple bolts and wing nuts.
