I've seen photos of people losing their trim / Keder rail on the highway. I thought I saw something about some clips or something that can be used to prevent this from happening. I've attached a photo of the rail on my T@b 360 which appears to be rising up at the top. Can anyone tell me about the clips?
Anone with plastic house gutters has witnessed the inches of lengthwise movement between hot and cold.
I'd be leery of through bolting plastic as done in the video, without slotted holes to accommodate expansion. It may just crack if firmly held.
Silicone caulk has only modest adhesive properties, ir is not a construction adhesive.
A clear polysulfide caulk or black rubberized caulk may work better.
It would be good to hear from folks who have modified this trim fastening, one to several years after the fact. What works or doesn't.
Additionally, why on earth are we all accepting a flawed manufacturer detail that puts us at risk of being responsible for flying projectiles to others at highway speed?
On an automobile this would lead to lawsuits, NTSB investigation, and manufacturer recall.
I believe we should be writing to Nucamp and demanding a no cost fix of this consistent trim failure.
Would you accept the failure of front storage box fasteners leading to boxes littering the highway? How about wheel lugs rotting leading to wheel loss?
Where should we draw the line.
Southern Maryland
I never had an issue with my 2015 TAB 320, 2021 TAB 320, ir the prototype.
(longer screw and stainless steel fender washer)
