The Alde Connect panel in our 2021 Tab Boondock 400 is now presenting a low battery alarm.  A
forum question referred to a Victron setting that does not appear on my updated copy of the Victron app; there is no "Starter" to delete. The trailer's breaker panel shows no tripped breaker.
For the first couple of years we had no electrical troubles at all - amongst other things, our TV had a 7-pin connector to the trailer. The last 2+ years the TV had a 4-pin connector connected to an Autowbrake brake controller. I've not seen any adverse issues with Autowbrake in this forum, but I wonder...
Below are images  of Victron Connect's view of our trailer. Perhaps there's some clue to why we get a low battery alarm now.
                2020 Toyota Highlander + 2021 T@B 400 BD
Truckee, CA, expat, now driving out of Reno
Victron App also notes the Charger is off.
Are you now on Shore Power? If yes, could be the Power Center Convertor/Charger has failed.
Try toggling the Circuit Breakers off/on.
Try turning off the Battery Cut-Off Switch . . . do any cabin lights work? No. Convertor issue.
If you are not on Shore Power, perhaps the solar controller has failed . . . or a wire connection has become loose. Inspect all wire connections.
2024 Kia EV9
By the way - what is "PV"?
None of the literature from the dealer shows info about battery setup.
Am I correct in thinking that to confirm the battery setup: all bedding should be removed. The rearmost panel (which extends the width of the trailer) needs to be removed.???
2024 Kia EV9
Edit: Post-mortem battery info
Harris battery HBDAGMGC6-A; "101420" is date of manufacture; "FH" likely Flat Handle.
end edit
No apparent wire connection issues.
PS: Victron reports 13.88 VDC; DVM reports 13.46 VDC.
By the way: I was not at all amused to find the seal around the perimeter of the battery compartment trapped by by a strip of wood to capture the screws holding the hinges in place.
2024 Kia EV9
The brand label and capacity information most likely on the side of each.
Which could be due to turning off trailer VDC loads and/or the solar controller starting to charge.
What have you changed since the original ~10.5V App data post.
Sounds like the only definitive IDing of the batteries is to pull one up. That option is not currently available - I've been obliged to get the trailer of the street. It's now in storage about 20 minutes away. It'll be a couple of weeks before I pull it back out.
I'll open a new question when the trailer is readily available. Any suggestions for in the mean time?
Plus, thanks immensely to all who've participated here.
John, Northern California
If your storage location has sunlight.
Keep Battery Cut-Off Switch on.
Turn off everything you can in the trailer.
Make sure the Inverter is fully off.
Consider removing Fuse Panel Fuse for Fridge so it is fully off not in a possible standby mode.
Check your Battery Status in a couple of days.
To make sure I understand your suggestions:
- Next time I'm up to the yard, turn the battery cut-off back on
- Once that's done, turn off anything (e.g., the useless radio+ device) that comes back on
- How does one turn off the inverter (if that's the blue device adjacent to the batteries)?
- I'll check the Norcold 3-way pamphlet to see if it has a standby mode
- Check battery status after a couple of days. What would be good news? bad news?
Thanks!Truckee, CA, expat, now driving out of Reno
Yes, you've got the general idea.
'Good' news would be the battery voltage being near normal in a day or two.
But that is a long shot as you haven't done anything to change the one-day-good, next-day-bad status.
Once the trailer is back at home consider removing both batteries and having an Auto Supply test them.
Also consider fully retracing all the solar & battery positive and ground wires looking for damage, corrosion, loose fittings, or blown fuses.
Different model years have slightly different controls . . . in general the Inverter has a switch in the small driver side bed area forward cubby. It will be small and look like a switch or larger and like this one:
shutdown = all breakers turned off (includes inverter)
battery on:
Q: What's the 35 watts doing?
Solar Controller is outputting 13.8V * 2.4A = 33 watts to the trailer 12VDC system.
You would need to see the Shunt to say more.
As for your power-down of trailer.
No harm in turning off the 120VAC circuit breakers however they have no impact on the 12VDC side of the trailer. Various 12VDC items like radio clock / back light, digital control pads waiting on a button push, inverter left on, carbon monoxide detector [ normally wired directly to battery +12V, not fused by power center fuse panel ], and solar controller ( at night ) are the types of things to try and turn off when possible . . . . as well has fans, lights of course.
Above data looks promising as Controller appears to be working.
Now will the AGM Batteries actually charge . . . .
Consider disconnecting at Negative terminal next time at trailer, letting them rest/sit for 5-10 minutes, then measuring each battery and the batteries in series to see if the charging worked.
I flipped the breakers, in large measure, because I thought the topmost kept the inverter off. Did I miss something there? The actual inverter switch looked the same before and after flipping breakers.
For a rig with OK-2-Good Batteries the background/parasitic current drain needs to be kept in mind but is not significant to system operation. If one does a lot of no shore power camping then adding extra power switches to background/parasitic current drain sources can be helpful . . . but it is not possible to eliminate them all.
Reducing the background/parasitic current drain while troubleshooting your issue was suggested to allow maximum Solar Panel power to go to the batteries, but don't worry if you could not.
As for the VDC-2-VAC Inverter.
Turning off the Power Center breaker has no impact when there is already no shore power available. The Inverter has two automatic operation modes. When on shore power the Inverter senses the available 120VAC and switches that power directly to the Inverter 120VAC output. When 120VAC is not detected then the Inverter automatically switches** to drawing power from the Batteries to supply the Inverter 120VAC output.
That would be a bad situation when trying to Solar charge the batteries as the Inverter can get power hungry.
** If the Cubby Space Switch is 'On' (it might have an LED indicator when on)
Also, the Inverter does not have a Power Center Fuse. Instead it uses a special high current in-line fuse.
All fuses pulled.
Here's a photo of the inverter switch after pressing its button. Before there was no light; now there's a green light. My guess is that the inverter was on from the start - but who nose?
Victron's contribution:
Your wording on the Inverter Control Panel is not clear to me.
As it appears you may have turned the Inverter On which was not the goal.
If there is either a Green or Yellow LED on then the Inverter is On. No LED equals Inverter fully Off.
Yellow LED = Inverter outlets powered by shore power
Green LED = Inverter outlets powered by trailer battery
Attached PDF file as part of a Forum discussion on how the Control Panel functions.
As for the Solar Panel Victron screen . . . no comment.
A screen capture of the Victron SmartShunt is also needed to understand what's happening.
Sorry, if earlier comments were confusing.
