Just for everyone's information. A few days ago we had our first tire blowout on our 2021 Tab 320S. These were the original tires (Trailer King) - 5 years old and with probably 10,000 miles on them. I inspect and check them regularly and there were no signs of anything amiss before this trip. I also check the pressure before every trip and it was set to the recommended 50psi. Were were also going 60mph on the interstate (I never exceed this speed). The weather was HOT.
Some notes:
(1) We heard a pop, but apart from some roughness, the trailer (towed by a Subaru Outback) remained absolutely stable. Luckily we were near an exit and were able to get off immediately and pull into to a gas station.
(2) Luckily the tire blew out in such a way that it cause no damage to the trailer.
(3) We called Coach-Net roadside assistance and they were helpful, but while they were finding a service person, we managed to replace the tire ourselves. A friendly passerby who happened to be a mechanic had a bottle jack that was better than mine. The issue with the Tab 320 is that a lot of jacks, even retracted, appear to be too tall to fit under the frame when the tire is flat. I have ordered a very short double-ram bottle jack that I'm hoping will be right, to carry in future.
(4) When we got home we replaced both tires with higher-rated tires. I will also replace the spare.
Luckily it all went pretty smoothly. Somethings I keep in mind:
- Never speed. You're on vacation, don't be in a rush. Don't exceed 60mph when towing and never exceed your tire's speed rating. Most tire store websites have good resources explaining the basics and how to understand the codes written on your tires. Also some good videos out there.
- Know and respect your tire specs. Educate yourself. Check pressure EVERY TIME you go out. I have always done this.
- Replace your tires EVERY FIVE YEARs, even if they look good. Tires deteriorate and they are not expensive enough that you want to risk major damage or worse, serious injury, from a blowout.
- Make sure you have good road side service and/or learn how to change a tire and make sure you carry the right tools.
I'd feared this eventuality, but we were lucky it wasn't so bad. I will feel even more prepared next time and learn whatever lessons I can.
Be safe everyone!
1 ·
Rolling the flat tire up onto your leveling blocks can give you enough room to fit the jack underneath.
Also often discussed has been the topic of bottle jacks and how other types of jacks (light weight floor jacks) are safer and also more capable. Many campers would never consider using either a scissor jack or a bottle jack for all of the obvious reasons....they do not fit, they are inclined to tip over, they may be at their lift limits.....
As has been often suggested, a good, lightweight floor jack resting on a plywood board is the safest choice. YMV
2017 F-150
Coeur d'Alene, Idaho
My scissor jack would not collapse low enough, so I had to call a friend to bring his floor jack to me. Essentially sitting on the rim, I measured the clearance between the concrete and the lift point of my 2021 320S (non-boondock). I determined that the jack had to be no taller than 3 1/2" in the collapsed position. Again, this is a 'non-boondock' model so I'm guessing this would be a 'worst case' scenario for the 320 models.
I have since bought a small floor jack from Amazon. It drops to 3 3/8" and comes with a nice, clean carrying case.
When I motorcycle camp I carry a tire plug kit and a small 12v air compressor to repair flats on the road. I only recently acquired a 320 Boondock and will carry those in it as well. It doesn't always work but when it does work it can help keep a bad day from becoming a terrible one
I've upgraded my tires now from C to D weight class.
PS: I'm skeptical that a TPMS can make much difference in such a situation. It's probably good for detecting a puncture or slow leak, but it probably won't give much warning of a sudden failure. If you're checking your pressure every time you go out, I'm not sure how much value a TPMS adds. It probably can't hurt if you don't neglect other prevention and precaution. I do also carry a puncture repair kit, but it definitely wouldn't have helped here as the tire was shredded.
managed by VE Smart Network
John, Northern California
Years ago, several brave owners even replaced their stabilizers with scissors jacks and used them for levelling. Although I was vocally skeptical of such a mod, no damage or failure was ever reported as far as I know.
DISCLAIMER: I'm not recommending, just reporting. YMMV!
