Black dripping Porch light gasket?
Two coats of clear nail polish worked nicely on ours, still good a year later.LauraC said:This black streak from light issue is happening on my 2025 T@b 360. How did the above mentioned sealant options work out? Not sure if I should try clear nail polish or a clear silicone sealant. It sounds like some silicone sealants won't adhere to the rubber. Thanks in advance!Susan & Bill, Yarmouth, Maine
2024 Kia EV91 -
Thanks for the info on Polycrylic and nail polish. Good to know it's still working for both of you!1
Since your's is still holding out after 3 years on a trailer, can you tell us what you bought? Sound like it's a good brandrfuss928 said:
The clear Polycrylic coating I used 3 years back is still working preventing any streaking. A very simple fix...LauraC said:This black streak from light issue is happening on my 2025 T@b 360. How did the above mentioned sealant options work out? Not sure if I should try clear nail polish or a clear silicone sealant. It sounds like some silicone sealants won't adhere to the rubber. Thanks in advance!2021 T@B320 S - 2013 Ridgeline - Ont. Can
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming WOW! What A RIDE!!” Dr. Hunter S. Thompson
