Does NuCamp provide a trailer equipment list ?
Purchased a 2025 400 black canyon. I would like an equipment list of all components in my trailer.
Should include brand , model and serial # .
Can I get such a list ? If so how do I get it
 thanks , Mike
    If you purchased it new, all the appliance brochures should have accompanied the trailer.
    Do you have an electronic copy of the manual?
  • MuttonChopsMuttonChops Member Posts: 1,875
    As @Sharon_is_SAM noted your dealer should have provided a hardcopy folder with all the sub-system manuals/information.  With that you can compile a 'listing' for your specific trailer.
    That said, no harm (potential good) in you personally verifying that the provided manuals match your equipment and while you are 'at it' confirm or capture the Model & Serial Numbers on each item.
    Could be helpful in the future.
  • MOS2MOS2 Member Posts: 25
    Appliance brochure are not what I am looking for . I want a list of each with model and serial Numbers
    The brochures don’t give that info .
    There's no such list that I have ever heard of. You would need to compile your own by locating and recording the info on your specific units.
    Ok that’s what I want to know
    it’s not hard for the manufacturer to provide this . It’s part of there build sheet .
    I know of at least one other rv manufactory that does this .
  • tabiphiletabiphile Member Posts: 468
    Component level serialization of 3rd party assemblies is extremely unusual in most industries. That's not to suggest that it isn't possible or done, but it is not the norm. Manufacturers will generally cherry pick high value critical assemblies for that kind of traceability. You would expect this for vision engines, cameras, possibly CPU's.
    The concern is always how far do you go? If there is a pc board in a unit, do you serialize the top level number?  Do you track revisions and components?
    It is not as easy to do as you might believe.
    In a highly controlled production facility, you might keep track of assembly revision levels that are built into a product and then depending upon granularity of the rev control you might drive revisions, part number or assembly changes. But in a modular build that is typical of these type of products, that would be somewhat constraining.
  • BinghiBinghi Member Posts: 391
    Which manufactory is that?
    Airstream
    MOS2 said:
    Airstream
    Could you provide an example of that? MRP/manufacturing systems do not simply burp this kind of information out. It needs to be entered/loaded in somewhere in that granularity to become available.
  • Yoshi_TABYoshi_TAB Member Posts: 547
    Hi,
     I'd be surprised if NuCamp  does not  have such a list for each build, but chooses not to share.
    I'm sure for recall (and other) reasons, they record the model and serial number of all components placed in the trailer.  That is standard manfacturing practice to record such data on some sort of shop traveler or such.
    2025 360 CS
    Southern Maryland
    I wonder why I never have received such a list from the manufacturer when I purchased a new car.
