Need fresh water tank for 2015 320 CS-S
Miwok
Member Posts: 19
We need to replace our freshwater tank. Our service agents haven't found one. Any suggestions? Is there a graveyard for T@B trailers?
Have you contacted a NuCamp dealer to see if they have one to sell you?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Most likely the water tank is an off the shelf product, just like many other components. If you try to take some measurements you might be able to match it to a tank from an RV supply or even Amazon.2
This 2015 is a pre-NuCamp (Pleasant Valley) -- no help coming from NuCamp so far. I have an extended warranty, so now trying to work out how to manage a 3rd party product and another party installation on warranty. Learning a lot. All advice welcome.0
From ~2012 on all T@Bs have been built in Sugarcreek OH by Pleasant Valley Trailers / NuCamp.Miwok said:This 2015 is a pre-NuCamp (Pleasant Valley) -- no help coming from NuCamp so far. I have an extended warranty, so now trying to work out how to manage a 3rd party product and another party installation on warranty. Learning a lot. All advice welcome.
I would be surprised if they stocked any specific parts for a 10 year old trailer. There may be someone in customer service that could find specs or possibly a drawing.
I would search for a standard tank with similar capacity and dimensions. There are lots to choose from even at a specific capacity. Expect to have to add some custom holes and fittings.
A good RV repair shop should be able to help or advise.
Still on the search. The tank is 36x20x4". No one seems to make such a thing.0
@Miwok, have you tried contacting "Plastic-Mart"?
They make RV fresh water storage tanks and holding tanks. Maybe they can make one to match whatever dimensions you need. If not, maybe they can refer you to someone who will. Good luck!!
https://www.plastic-mart.com/storage/ (866)-310-25562019 T@B 320 S Boondock Lite ~ 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ)2 -
Years ago I needed a replacement tank for my sailboat. Ronco Plastics had many sizes of tanks and placed appropriate fittings for me for no extra charge. I'd check there.2020 NuCamp T@B 320S Boondock
1995 Suburban :-)1
