Been RVing for years and have had a number of RVs , all with awnings .
So I now have a 2025 Black Canyon 400.
Thinking should I buy an awing or not .
Over the years I have noticed a number of RVers don’t use them .
So for the people that don’t use an awing , Why ?
With the larger awnings that stake down, that is likely not as much of a concern
Now if you're talking about side tents, we sold the one that came with our (used) T@B. Never used it. We much prefer a popup canopy that can be setup at any location on the campsite.
The one reason I do want one is as a rain porch over the door. Like a mini-visor. I looked at using a 320 visor, but they are basically as big as the 400 visors. I don't want to limit the door from opening all the way when not raining. So, no solution found yet...
Poughquag, NY
2020 Tacoma TRD Off-Road
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
Pros are:
- it was about $120
- it's great when it's raining as it keeps water out of your trailer when going in/out
- it keeps the front of the trailer cooler when it's hot
- it provides shade for two people to sit
- it packs up nicely and doesn't take up much space
Cons are:- It takes about 20 minutes to get fully setup if you count nailing in the tent stakes (but much less time than what I read for people with the nice All Pro or Pahaque varieties). Tear-down is much faster
- it flaps a lot when it's windy and may blow up and over the trailer in high winds
- putting up in breezy weather by yourself is a creative process
- taking it down in breezy weather is a creative process
Involve a friend if you set it up for the first time. You'll figure out how to set it up by yourself soon enough. The sew-on keder rail insert strip made it even easier to attach. Hire a seamstress who has an industrial sewing machine to sew on the strip. I hand-sewed it and it took foooooreeeever.After being awakened in the middle of the night from a fast moving storm that blew it up and off the front of the camper (before I had the keder rail insert sewed on) I've been trying to figure out an easy way partially disassemble it without fully removing it for the evening or times when I'm away from the camper. I've got a half-baked idea that involves unclipping the supporting poles and rolling all the poles up in the awning all the way to the keder rail like a rug. And with some well placed sewed-on velcro strips I could let it just hang rolled up on the side of the camper. I was going to try using carabiners at the base of the tent stakes to let me keep the stakes in the ground, but quickly disconnect for temporary roll-up. I am going to try it out when I have the time and I'll post if it works.
I really do enjoy having it on and love, love, love sitting out under it with a nice soft rain or staying cool in the shade. I can't find the King Camp for sale on Amazon anymore but this Hasika is almost identical.
2022 Nissan Pathfinder
Cary, North Carolina
Southern California
Full-timer since 2019
I mounted a couple of eye bolts by the door that the umbrella pole slides into. I cut the pole down so that it doesn't extend too far past the eye bolts. It drops in place and can be removed in seconds.
When we want better coverage, we use a pop up canopy that can be setup in more convenient locations at the campsite. It has optional bug screen and wind break side walls when necessary.
Trips - 48 Mileage - 63,452
