@floridamanif you intended to include a picture/image; there was an upload error - - nothing is displayed
I cannot directly answer your question. In general on TAB 400 with a factory installed Shunt: - 1 - There is one large wire from the battery negative terminal. - 2 - That wire leads directly to the shunt, - 3 - The other side of the shunt is wired to the Negative Side of a 12VDC Distribution block { a two terminal small item with several Positive and Negative connections. }
If its like mine, the actual shunt is circled in red above. The "Smart Shunt" Victron box I have seen I don't see here, but is that not a wireless Bluetooth connection to the shunt? You can clearly see the large black cable as the final connection to the battery, where it should be.
floridaman said:
. . . was looking for the victron device so I could read the PUK code because I forgot the password. I guess that’s not it?
The SHUNT shown in the above picture and a few of the earlier replies is a Victron SmartShunt. The PUK Code Label is located on the unit End, most likely the end facing the trailer front.
Here are the other items in your Battery Box Area:
Reference Video
