Recommended sewer hose length
Recently purchased a 2025 400.  What length or lengths should we buy?
  • Binghi
    Binghi Member Posts: 416
    I would buy two 10-ft hoses. Get good supple ones. The cheap hoses get brittle too fast and crack. Also get caps for the hose ends to reduce messes and smells.
  • pilot1each
    pilot1each Member Posts: 11
    Thanks
  • rfuss928
    rfuss928 Member Posts: 1,192
    edited February 15
    As @Binghi said, two 10 ft hoses are a good choice.  You'll also need an elbow for the connection at the campsite.  Either of these kits contain the key pieces.  There are several other similar choices.
    https://www.amazon.com/dp/B01HPHR30U/ref=sspa_dk_hqp_detail_aax_0?sp_csd=d2lkZ2V0TmFtZT1zcF9ocXBfc2hhcmVk&th=1
    https://www.amazon.com/dp/B00BDEPJ1W?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_7&th=1
  • mx4789
    mx4789 Member Posts: 72
    Might want to consider getting a dedicated water hose for the black tank flush connection. It probably wouldn't seem too obvious until you use a dump station.
    2025 Tab 320 S BD
    2024 Nissan Frontier
  • Mickerly
    Mickerly Member Posts: 506
    Two 10ft pieces is a great idea. You will mostly use one. When it is too short, you have more.
    You will need a clear, 90 degree bend. Without the clear section, you won't know when it's done.
    2018 320CS-S
    "Just Enough"
  • tabiphile
    tabiphile Member Posts: 472
    20 feet of hose seems like about 10 feet too much. In over 10 years, I have never needed more than one 10 foot section of hose. There were a few times when I needed to use nearly every inch, and there were a few times when I had to jockey around a bit to get close enough, but I have never encountered a situation where 10 feet did not suffice.
  • Bill&Suze
    Bill&Suze Member Posts: 179
    I have 15 feet which has been plenty. If you are at camping sites with a sewer sump provided you should usually be able to position the camper within that distance
    Susan & Bill, Yarmouth, Maine
    2024 Kia EV9
  • elbolillo
    elbolillo Member Posts: 575
    15' has been plenty for our needs.
  • AnOldUR
    AnOldUR Member Posts: 1,759
    edited February 18
    A few years ago I purchased a Rhino waste tank that I use at home when there isn't a convenient dump stop on the way home. It came with a three foot sewer hose. I travel with that and a 10' hose. Both fit in the storage tube below our T@B. With some dump stations the short hose works better than having to work with clumsy excess length. Other times I may have to connect the two together to reach the opening. The majority of the time the ten foot hose alone works fine.
  • pak
    pak Member Posts: 133
    We have one 15' which has been enough. Sometimes we have had to turn around. Also, have been too low at times. 2017 320 CS-S
