Recommended sewer hose length
pilot1each
Member Posts: 8
Recently purchased a 2025 400. What length or lengths should we buy?
I would buy two 10-ft hoses. Get good supple ones. The cheap hoses get brittle too fast and crack. Also get caps for the hose ends to reduce messes and smells.
2 -
Thanks0
As @Binghi said, two 10 ft hoses are a good choice. You'll also need an elbow for the connection at the campsite. Either of these kits contain the key pieces. There are several other similar choices.
https://www.amazon.com/dp/B01HPHR30U/ref=sspa_dk_hqp_detail_aax_0?sp_csd=d2lkZ2V0TmFtZT1zcF9ocXBfc2hhcmVk&th=1
https://www.amazon.com/dp/B00BDEPJ1W?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_7&th=1
Might want to consider getting a dedicated water hose for the black tank flush connection. It probably wouldn't seem too obvious until you use a dump station.2025 Tab 320 S BD2024 Nissan Frontier2
Two 10ft pieces is a great idea. You will mostly use one. When it is too short, you have more.
You will need a clear, 90 degree bend. Without the clear section, you won't know when it's done.2018 320CS-S
"Just Enough"0 -
20 feet of hose seems like about 10 feet too much. In over 10 years, I have never needed more than one 10 foot section of hose. There were a few times when I needed to use nearly every inch, and there were a few times when I had to jockey around a bit to get close enough, but I have never encountered a situation where 10 feet did not suffice.1
I have 15 feet which has been plenty. If you are at camping sites with a sewer sump provided you should usually be able to position the camper within that distanceSusan & Bill, Yarmouth, Maine
2024 Kia EV90 -
15' has been plenty for our needs.
Ken / 2023 Tab 400 “La Bolita” (39,000+ miles) / 2024 Toyota Sequoia0 -
A few years ago I purchased a Rhino waste tank that I use at home when there isn't a convenient dump stop on the way home. It came with a three foot sewer hose. I travel with that and a 10' hose. Both fit in the storage tube below our T@B. With some dump stations the short hose works better than having to work with clumsy excess length. Other times I may have to connect the two together to reach the opening. The majority of the time the ten foot hose alone works fine.
We have one 15' which has been enough. Sometimes we have had to turn around. Also, have been too low at times. 2017 320 CS-S0
- 143 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 918 Tips & Tricks
