Remove duct tape residue from 2021 tab400 BD exterior
Gkopan
Gkopan Member Posts: 47
What is the safest way to remove duct tape residue from exterior Azdel and plastic and rubber trim? (I taped down loose black rubber trim that was flopping around during heavy wind when coming across Kansas!) Thanks! See photo
2021 T@B 400 Boondock; TV: 2019 F150 3.5 EB
  • Gkopan
  • GBL_citruscountyfl
    GBL_citruscountyfl Member Posts: 35
    WD 40 is the only.product that won't damage the cheap plastic trim. The fiberglass exterior is more forgiving, but I only use WD-40 on my rv.
    2018 Honda Ridgeline FWD
    2020 400 solo
  • Gomers2
    Gomers2 Member Posts: 172
    I would try GooGone. Citrus based and works really well. Test it someplace inconspicuous?
  • Bayliss
    Bayliss Member Posts: 1,535
    I second @Gomers2's suggestion. GooGone has worked well for me, although I do not recall specifically using it on the plastic trim, so the testing suggestion is good.
  • Horigan
    Horigan Member Posts: 928
    Rich
    2019 T@b 400
    Bellingham WA
  • Voyager
    Voyager Member Posts: 63
    I used Goof Off to remove a bumper sticker and this is the result
    2019 T@b 320 S 2nd owner
    Nissan Pathfinder
    Central MA
  • Gomers2
    Ooh, that's a bummer. That's a much stronger product, for paint spills I think. Now you need a bigger bumper sticker😁
  • AndreO
    AndreO Member Posts: 88
    I use lighter fluid. It has never had a negative effect on any of my plastic items so far and breaks down most lable and tape adhesives.
    AndreO
    Ontario, Canada
    2018 Tab 400
    Ford F150 2.7 Lariat
  • ckjs
    ckjs Member Posts: 144
    I’ve avoided duct tape ever since I needed to remove it cleanly. No luck.
    Aluminum foil tape is a lot easier to use. I’ve heard good things about about gaffer’s tape too, though no personal experience with removing it.
