Remove duct tape residue from 2021 tab400 BD exterior
What is the safest way to remove duct tape residue from exterior Azdel and plastic and rubber trim? (I taped down loose black rubber trim that was flopping around during heavy wind when coming across Kansas!) Thanks! See photo
WD 40 is the only.product that won't damage the cheap plastic trim. The fiberglass exterior is more forgiving, but I only use WD-40 on my rv.
2018 Honda Ridgeline FWD
2020 400 solo
Fulltime rving since 2006/ tab since 20210 -
I would try GooGone. Citrus based and works really well. Test it someplace inconspicuous?
I used Goof Off to remove a bumper sticker and this is the result
2019 T@b 320 S 2nd owner
Nissan Pathfinder
Central MA
Ooh, that's a bummer. That's a much stronger product, for paint spills I think. Now you need a bigger bumper sticker😁
I use lighter fluid. It has never had a negative effect on any of my plastic items so far and breaks down most lable and tape adhesives.
AndreO
Ontario, Canada
2018 Tab 400
Ford F150 2.7 Lariat0 -
I’ve avoided duct tape ever since I needed to remove it cleanly. No luck.
Aluminum foil tape is a lot easier to use. I’ve heard good things about about gaffer’s tape too, though no personal experience with removing it.Charles & Judy, Santa Cruz, CA
2018 T@B 320 CS-S; Alde 3020; 4 cyl 2020 Subaru Outback Onyx XT0
