low pressure campstove
Any suggestions for purchasing a low pressure camp stove to use with the LP quick connect at the rear fo the 360?
  • Gomers2
    Gomers2 Member Posts: 141
    See your other post re tanks. I looked at a lot of low pressure stoves and none really fit the bill. Wound up with a Camp Chef that has been fantastic. It's high pressure though, and is split off the tank before the regulator. Had
    wanted to use that quick connect, but it's just not as easy as you'd think it would be.
  • phillm47
    phillm47 Member Posts: 10
    edited 10:40AM
    Retired engineer here, who recently went down this rabbit hole. Quick answers are, Blackstone (all), Weber traveler RV (hard to store) and Weber Q1200 (with this conversation kit). Amazon has gas hose options for these choices; keep the hose length on the short side (8-14') as pressure drops for total length of pipe/hose from LP tank, affecting grill performance. You can always remove the LP regulator off a grill or stove, but this is not a sure thing, depending on the grill - I chose not to go there.
    Plan B: Install a "Y" or "T" on the outlet of the 20 pound LP cylinder as Gomers2 pictured. This will allow you to use any grill/stove…and a longer hose too. You will be "somewhat" limited to grill/stove location.
    My choice? My end game for my camper is for my wife and I is to travel 3-4 weeks at a time, touring national parks. Being limited to griddle only, or grill only, meals is not an option. We ended up buying a Camp Chef Everest X2 camp stove, Lodge cast iron reversible griddle plate and a 5 lb LP grower kit. I may install a tee at my 20 lb tank as well, as Gomers2 pictured; Nice to have options.
    2025 T@B 320 S BDBC
    2024 Jeep Grand Cherokee Overland 4x4
    NE Indiana
  • Gomers2
    The Camp Chef Everest is really solid. We started with a lodge pan and moved to the GreenPan set, which is also great, and lighter. Stove goes on a 2x2 folding table in front, with the storage tub top as a work area as well.
  • gkreitzburg
    gkreitzburg Member Posts: 70
    edited 1:23PM
    Depends on your requirements. We have a cadac and have found it quite adequate: 2 cook 3 pro
    used it with the tab400 and now with the haven.
    2023 T@B 400 Boondock
    2026 Haven 220
