Weak shower floor fix - Solved
rydfree
rydfree Member Posts: 44
edited September 26 in Modifications & Upgrades
I searched but only came up with a post of an earlier year model that doesn't seem to look like mine. Has anyone reinforced the shower pan in a 2025 320 ? I can't believe NuCamp let these things out with the shower pan flexing that much ! Anytime the wife or myself steps between the floor drain and outside wall it feels as though the shower pan might rip from the wall . There has got to be 2" of void between the pan and floor of the camper. I would rather fix the issue before it starts cracking and possibly leaking. I looked from the inside of the wheel well area (under the Television ) but could not see anything. I was hoping to be able to at least shoot some foam under there, but did not see any access to the area in question. I did not see any access from underneath the camper either but I did not drop the plastic liner . Any advice would be appreciated.
  • Bayliss
    Bayliss Member Posts: 1,535
    @rydfree, I do not have an answer for you, but did find this post that may be of interest. I do not know it is the post you referenced above (I am thinking of a different discussion), so I am sending it along just in case. Good luck!!
  • rydfree
    Thanks, I had not seen that particular thread, but it seems it died without any updates on how to fix.
  • Caboos
    Caboos Member Posts: 13
    we have a 2026 360 and after one stepmom the bathroom floor I ordered a wooden shower mat that fots over the majority so now is stable
  • Yoshi_TAB
    Yoshi_TAB Member Posts: 597
    Hi,
    There is a 3 part video on you tube on how someone reinforced the shower floor. Can’t seem to find the link , but here is a picture that might help to find it.
    2025 360 CS
    Southern Maryland
  • rydfree
    Thanks for the video suggestion. That is a video that I watched a few months ago but his 2015 is more accessible to that area than my 2025. My floor drain is in the center and I don't have that access box underneath, unless it is hidden under the plastic liner that is covering the bottom of my Tab. I also could not see anything from the wheel well area as he did. I am going to try that again tomorrow and see if I just wasn't bending my old body enough to get a proper look, lol. I watched one video, not sure if it was his though, where they actually cut a small square out of the shower pan near the edge and filled with foam underneath then Fiber glassed a repair patch in. I don't care to go that route unless it has begun to crack already. I'm going to do something, just haven't figured out what exactly yet. That bottom flexes way too much for my comfort.
    pthomas745 Administrator, Moderator Posts: 4,704
    There are a lot of different threads that show what is happening under the shower pan, that are not necessarily about a soft shower pan. There are a lot of posts about the broken gray tank drain that is located all under the shower pan.
    This is just one, and it does include the links to the Mark Turney videos that were posted above.
    Cracked Shower Pan
    Here is another, but on a 400. After you get the area under shower pan uncovered, there isn't a lot of variance in either the 400 or 320, it seems to me.
    Broken gray tank drain
  • rydfree
    I finally got around to fixing the flexing shower pan on our 2025 320. After looking again, I found the removeable cover that hides the shower drain P-trap. I'm not sure how I missed seeing it before, but I'll blame old age and not liking crawling around on the floor. Anyway, no need to remove the underbelly plastic barrier so that was a plus. After removing the cover and seeing the P-trap I could lift up on the drain and put a 1/2" gap between the shower pan and the wood sub floor. I went to Home Depot and got a can of spray foam and a roll of their smallest tubing. The tubing fit rather tight on the nozzle, but I had to heat it up a bit and tighten a wire tie around it to stop foam from squirting out. It was then easy to slide the tubing under the shower pan to get foam in the corners. I Then quickly placed a heavy weight directly in the center of the pan on top of the drain to keep the foam from pushing the low point of the drain upward. The shower pan is solid now and feels much, much better.
