Lark et al, I have been reading the discussion on squeezing my 2013 Q Max thru the garage door challenge. Went to the Northern tools website to look up the 12 inch rims. Seems like they are generally full wheel kits and I don't want a tire on the rim, right? Wondered which rim you used? So as I understand it I buy the small diameter rim and put them on where the usual tire was just removed from. I don't have an ac vent ontop just the fan cover that seems to about an inch of height on the roof.
I have 84 inches of height available.
Is it that straight forward?
Will be putting it away for the winter and pulling it out 5 months later after the snow melts in April....Appreciate any advice. Would love to have access to the t@b all winter to tinker and dream with in the garage if I could!
Thanks, Dave
                2 ·
You must jack at the back of the frame towards the rear of the trailer and not on the axle. I made a "stand" for the first rim I put on. What I mean is when you remove the first wheel and place on the 12" rim, I put my 2x4 built "Stand" underneath the rim and lower the jack slowly. The height of the stand is 3 flat 2x4's high. If you don't do this, you may find it difficult to remove your jack once down. Then I proceed to the other side, jack/remove/put on rim/lower this side to the ground slowly. Then back to the other side, jack/remove stand/lower rim to the ground. Then I unhitch from TV and roll into garage. I know it sounds like a lot of work but I must do this where I live. It is also a bonus to go out and do mods whenever you want and know all is secure.
I will go and take a picture of my crappy made stand if you want to replicate....it works for me! Talk to you soon.
This is just an idea, have you guys looked in to a set of car dollies? they should give you the clearance you need and you could skip the rims altogether. they come in a pair for $80.00 bucks at NT, just take off the rims and wheels and set the axle directly on the dollies. This would allow you to roll it in any direction you want since they have castor wheels on them. again this is just an idea, please check for clearance and height first. here is the link to what I am talking about
http://www.northerntool.com/shop/tools/product_200578635_200578635
You lost me there, uh... yeah! 12" rims ("NO TIRE") and roll into the garage.
So I went into this skeptically, but after your encouragement, bought the
Thanks
Dave!
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
Love the photo's and instructions... but am left with two questions for you or others who have been succesful with tucking thier t@b into the 84" garage.
1) how much clearance below the t@b is there using the 12in rims?
2) could you post the dimensions for your "stand" (3 2x4's on top of each other)
I am contemplating using a 10in rim (instead of 12) hoping to give me a tad bit more clearance at the top, but not scraping off the bottom. I have a 2016 Max S model which has the Air Conditioning exhaust stack on top of the roof. It is approx 2 1/2 inches above the roof, and appears to be about 1/4 inch taller than the vent cover. So, removing the vent cover does me no good with the stack still a factor.
Also, could you post how your stand is placed under the rim? It appears to "cradle" the rim (does not allow the rim to roll back or forth. But still holds it up off the ground a few inches allowing the jack to be removed from under the t@b. I am assuming that it was designed to fit snug against the rim on three sides (no play)...
-Bubba
Answer #1: One (1) inch clearance from axle frame to ground.
#2: I could if I had them...I think it is 18" long and maybe 6" wide at base.
If you look at Daveincaz' picture, you can see he didn't cut down the front jack to lower the front. That is why his looks real high in the front and not level. Doing that gives you greater clearance...but looks like he didn't need to.
I don't know if you misunderstood me or if I posted the wrong verbage....but I DO NOT remove the cover for my fantastic fan. I remove the A/C "Vent stack" in order to get proper clearance.
Your observation for the stand is correct. I can't provide a picture at present. I really didn't spend much time making It or ensuring a snug fit. I mounted those two blocks on top to ensure the rim wouldn't roll off the stand.
Hope this helps! By the way, my garage clearance is 83.5
And can you link me to your description of how you lowered the front crank wheel? I think I've read through these descriptions a few times, but I can't seem to find your description or photos of how you lowered the front crank. Thanks! I'm working with a 2015 320CX-S ....so we have gray/black water drains at the front of the trailer.
2017 T@B 320 Max S
2014 Ford Escape 2.0 EcoBoost
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
