 Pop-T@B
                    Member Posts: 199
Pop-T@B
                    Member Posts: 199
            For those of you that have soft water at home and would like to also have it in their T@B as I do, there is a small solution. Most of the RV water softeners I have seen in the market place were too big to store easily in the T@B, you would either need to store them inside the camper or in the tow vehicle. Then set it up outside to hook it up. After I found a place to store my sewer hose and sewer items (see my other post on “sewer hose storage solution”) it opened up some space inside the front storage box. I work in Water Conditioning so I made a short custom water softener. With the factory sewer hose storage pipe removed I was able to fit a 6”x13” mineral tank with an 1190FP Clack in and out head on it. The unit should soften about 100 gallons of water before it needs to be regenerated with 2# of salt. If you are interested you should be able to get one made by your local water conditioning company, if they need details on how I made it, I will be happy you share the info. I can also store 4 wheel chocks and a 25 RV water hose in the box with it.
Thanks, Shawn
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
for a campsite regen you would shut off the water supply, unhook the hose feeding the RV and run it over to a proper drain, unscrew the cap and slowly pour #2lbs of table salt that has been dissolved in water into the top of the unit, reinstall the cap, let set for about 10-15minutes then slowly turn on the feed water to rinse out the salt thru the drain hose, run water until you can no longer taste salt in the drain water, reinstall hose to RV inlet and you are ready to go. Total time to regen is about 20-25 minutes, best time to do this is during your morning cup of coffee and reading the newspaper.
Amazing...
Southern California
Full-timer since 2019
I will email Spencer regarding the Alde.
Southern California
I found this in the Alde 3020 manual, but no discussion of a water softener.
