In the shower, behind the toilet, is a little door. Inside
the door, mounted to the corner is a plastic container.
A tube hangs from this container into open space. I'm
assuming this is some type of "overflow". Couldn't
find "squat" (pun intended) in the owners manual. Can someone
clue me in?
                t@b sofitel max cs/s - Heartland USA
0 ·
sink in the clamshell but thanks for the thought.
They realy should have an individual manual for each model they sell. I'm very pleased with it thus far but it seems like there is way too much left to know even after studying the books cover to cover.
enough to overflow. Thanks friend!
The hose he’s referring to comes out of the Alde heater's Glycol fill tank and is a breather hose only, not a drain. It’s designed to allow pressure to escape from the boiler due to expansion of the Glycol as it’s being heated.
It will not leak fluid if the tank is filled to its proper level.
I have read the forum for this info but couldn't find a definitive answer....Looked for the elusive Alde glycol tank today. Have read through the forum and it makes sense it would be in the hatch behind the toilet in the CS-S; this is the only place I did not look today :-/ Is this its hiding place?
I also checked all the valves for correct camping season position (which are under the sink in the clamshell area) against a photo found here and we have 6 vs. 5 valves. They are also in different positions from the photo. So I basically judged the correct position from whether it was parallel or perpendicular to the pipe. Is this "probably" correct? We have a CS-S 2016 version I believe and added a kitchen sink and cabinet inside the T@b.
Many Thanks in advance T@b gurus!
I am hoping it is there when I check tomorrow. Also , being non-mechanically-inclined I wish the valves were just labeled summer and winter!
Keep in mind a few specialty valves look and work differently. For example, in my 2015 S, the valve to drain the Alde HW tank is a plastic yellow handle you pull up (perpendicular to the line) to open.
I was just researching something else and found your post about this and your labelmaker.
I am thinking a labelmaker sounds like something I need!
It was so nice to go outside at midnight (long story, I got interrupted and sidetracked on my winterizing task earlier) and have the confidence to just look at each label and move each valve to the correct position. The Alde water heater drained on the ground, nothing blew up--GREAT! I am so glad I spent so much time on the labels!
The labels are still stuck (knock on wood). I did use a cordless Dust Buster and a damp rag to get all of the visible sawdust out of there (where does it hide??? There's still more in there!). I'm going to look for a clear tape to put over the labels to keep them stuck to the floor. It's yet another entry on my Verna-do list.
