Thanks...I missed that, somehow.John&Kris said:That is the one. The beginning of this post talked about us having to get a backing plate like one that Kevin used on Facebook "Please note: the base includes the bracket needed inside, but consumer will need to engineer their own backing, like the gentleman on Facebook, Kevin Ressler."
which I could never find. I will see how large the plate is and may use a larger one just to be on the safe side.
I agree with the mounting plate.ChanW said:I had the impression that they were talking about a "backing plate" on the inside of the bench for added strength.
The picture Jenn shows, I would call a "mounting plate", but that's just me. No pressure.
No, PXLated, I see the drop leaves, too.PXLated said:That one in the video looked to me like it might have drop down leaves - a center piece and a leaf on each side. Or am I just being visually impaired today?
LOL!!!RZRBUG said:Should be a sweet table, Mike. I see that he's using honey to hold it together.
John&Kris, someone mentioned IKEA and they had a number of table tops you could easily screw to the Lagun. Do a search for Lagun and I'm sure you can find the link. Another person took the table top off of the $18 Walmart or Camping World plastic table top to use. Someone even took the original tabletop off and is using it. Home Improvement stores do have premade table tops and they will sometimes cut to size for you.John&Kris said:Well it appears that the table tops for the Lagun will not be available until the 2017 Models come out
