How about using a box cutter to cut around the label and gain access to check the water inside the cells and fill as necessary?sabel said:I have several questions too. My battery has screw caps on top suggesting water level needs to be checked. But there's also a battery info sticker over most of the caps so you can't actually open any of them. Anyone else got that situation?
I have a 50 watt Renogy panel mounted on my garage with a 30 amp controller and it works great. If it were me and I was using the 10 watt panel I would install a battery shutoff switch near the battery to eliminate any parasitic draw from the T@B and use the 10 watt panel to supplement the charge while the trailer is sitting idle. You could initially plug the trailer in to shore power, charge the battery up fully, unplug and then begin using the smaller panel to supplement a charge while sitting idle. As a safety check you could periodically plug in a small LED volt-meter and check the charge to ensure the battery is up to snuff.sabel said:
I've stored our T@B for the winter and left the battery in it. Has anyone tried the Zamp Solar Battery Maintainer plugged into the stock plug? I'm considering the 10 watt panel with controler.
That's exactly what I did. I picked up a 50 watt panel for another purpose and now use it with a controller to keep the battery topped offMichigan_Mike said:How about using a box cutter to cut around the label and gain access to check the water inside the cells and fill as necessary?sabel said:I have several questions too. My battery has screw caps on top suggesting water level needs to be checked. But there's also a battery info sticker over most of the caps so you can't actually open any of them. Anyone else got that situation?I have a 50 watt Renogy panel mounted on my garage with a 30 amp controller and it works great. If it were me and I was using the 10 watt panel I would install a battery shutoff switch near the battery to eliminate any parasitic draw from the T@B and use the 10 watt panel to supplement the charge while the trailer is sitting idle. You could initially plug the trailer in to shore power, charge the battery up fully, unplug and then begin using the smaller panel to supplement a charge while sitting idle. As a safety check you could periodically plug in a small LED volt-meter and check the charge to ensure the battery is up to snuff.sabel said:
Yes, if you are on shore power the converter will automatically switch to a trickle charge mode.LauraRey said:If I'm using the trailer, even in cold weather, can I just leave it hooked up to "shore" power? I assumed that would take care of the battery as well.
Not always. Our WFCO converters are notorious. Mine would switch to 13.2v after 2 days, but then a day later it should switch back to 13.7 and stay there permanently, boiling the battery. But now, it's stuck at 13.2 and won't budge no matter what I do. I even had it kick into boost mode without warning on me 2 weeks ago!Cyclonic said:Yes, if you are on shore power the converter will automatically switch to a trickle charge mode.LauraRey said:If I'm using the trailer, even in cold weather, can I just leave it hooked up to "shore" power? I assumed that would take care of the battery as well.
The Genius G1100 that I think he is using there has an automatic de-sulphation pulse as well. It is a very good battery charger/maintainer.rfuss928 said:I highly recommend a battery maintainer that has a de-sulphation pulse incorporated in its output. This is a proven process to maintain battery capacity and extend useful life. They are generally more expensive than simpler units (~$50) but are very effective. Two well known and respected brands are BatteryMinder and CTek.
Just checked...it is at 13.3. Thanks for the advice.wizard1880 said:Ensure it stays at 13.2 after 2 days of no use, and re-check every week to verify! This is especially important if you have AGM batteries (optima, lifeline, etc)
wizard1880 said:...
That said, another reason for early battery death can be overcharge. The WFCO converters in our T@Bs are notorious for killing batteries if you leave them plugged in all the time. Especially during the hot summer months they can boil your battery dry and destroy them in a year or so.
