The valves on my T@b valves seem to be opposite the diagrams for winterization. I simply reversed them to put until winter mode, but for some reason, I am second guessing myself. Is there a way to test it without putting water back in the tank or lines?
We have had an unusually warm fall and I am just getting around to winterizing. We had already been through weather cold enough to break my outside underground by this time last year.
Valves open - no pressure at the faucet.
I assume the Alde is bypassed.
Note that the plastic yellow drain valve for the Alde is a little different. If it's sticking up from the pipe, the drain to the outside is open. If it's laying down on the pipe (in either direction) the drain is closed, but fluid can still flow through the valve.
Don't hold your breath. It would be nice, but out of the ordinary. This type of stuff is usually done by a dealer.
