Pop-T@B
Member Posts: 199
I have seen quite a few posts on this, just thought I would share what I made for mine. I used two pieces of white maple for the rails, all wood is finished with a satin clear coat. The slats are made out of 6 pieces of Poplar wood 29” long by 5-1/8” wide, they fit the space perfectly. I used poplar due to cost and no one sees them. I routed all edges and sanded smooth, I stapled the pieces together with a flat bungee cord to hold them all together, so I did not end up with six loose pieces. This made them easy to setup and to store. I store them in the no-man’s land cabinet under the bench on the left side. I made brackets to hold them up off of any plumbing or wiring and they are held tightly in place with a bungee cord, so as not to damage anything. We removed the large table for good, to give us the extra floor space. We use a small fold up table that stores under the couch seat on the right side. This makes the bed set up much easier and we love the added room to move around.
2016 Silver/Black T@B M@x S with Scuba Black interior. 2015 Lincoln MKC AWD 2.0L Ecoboost tow vehicle. Tekonsha Prodigy wireless Brake Controller.
Well done!
I decided to use three 1/4-20 through bolts and a #12 wood screw at the rear. You see them on the outside, but I feel like they are a bit more durable than just wood screws....
For now I just store the slats on top the spare tire in the big rear box...
What thickness is the wood you are using for the bed slats to support the weight placed on them from above?
South Carolina
Its hard to see, but when I took the picture the vent slot was slightly covered, I have since took the support back off and routed a slot in it. the board was 1-1/2"-3/4"
~ Joe
http://www.rei.com/product/866035/gci-outdoor-compact-camp-table-25
~ Joe
Thanks
Charlie
Thanks,
Charlie Borton
2016 T@B Outback
I stapled it on first in one piece, then when I went to fold it I had it to tight and it would not fold correctly. I would suggest start with the first board, staple it on, then fold staple to the next and so and and so on. I should have done it this way, but no one see it be me so I just left it this way.
And yes, that is the Ikea Toftbo, nice rug!
2022 Ford F350 Tremor | 2022 Cirrus 620
