Lexus RX
Does anyone tow their T@B with a Lexus RX?
If so how did you deal with getting a 7 pin fully wired? We would like to get an RX next and then use a the RF Brake Controller?
South Carolina
  • Lisa33Lisa33 Member Posts: 260
    I tow my T@DA with a Lexus RX450h (hybrid).  The Lexus tow package did not include a charge line in the 7-blade connector.  As you've realized, you need that for the Prodigy RF controller.  I had Preston from Miller Trailer Sales wire a separate charge line to the auxiliary battery in the vehicle (not the hybrid batteries).
  • John_and_KrisJohn_and_Kris Member Posts: 302
    Thanks I 'm a little concerned about giving the manufacturer an out regarding warranty on a $50k car when you have to cut wires to install a 7 pin over the 4  flt pin.
    South Carolina
  • webcrawlerwebcrawler Member Posts: 133
    edited November 2015
    Do not cut the 4 pin wiring.  I used this adapter:
    http://www.amazon.com/gp/product/B0002Q7C1C?psc=1&redirect=true&ref_=oh_aui_detailpage_o09_s00
    I still have a flat 4 for my little boat trailer.
    I slightly modified the included bracket to bolt directly to the existing flat 4 mount. That way, it is easy to put back to 100% stock and
    Many small SUV's have an electrical box in the rear and you can tap a line in that.  My Lincoln MKC had a spare 30A fuse just for this purpose.  I only had to run the 10 GA wire (12 ga would be fine for that short of a run as well) from the fuse terminal dow to the 7 Pin socket.  This was only about a 5' run total.  I was careful to run the wire through he correct body grommet to make sure is could not short out on any metal.
    Some times a little poking around in the rear compartment can save a lot of effort to run the wire all the way up to the battery...
    Kennesaw, Georgia
    2016 Silver/Black T@B M@x S with Scuba Black interior.  2015 Lincoln MKC AWD 2.0L Ecoboost tow vehicle. Tekonsha Prodigy wireless Brake Controller.
    Thanks
    South Carolina
    Thanks for all the comments. We have a "15 GX and were thinking of downsizing to an RX. Will wait and see what the hitch etc is like on the new re-designed "16 Rx's
    South Carolina
    I had the Lexus dealer install the 7 blade adapter prior to delivery.
    Lisa33  What did you use for a brake controller? The GM at our Dealership said there should not be any problem doing this or with warranty as they will do it.
    Thanks
    South Carolina
    Lisa33 Sorry for the questions I now started up further and you answered all my questions. Sorry for the fat finger of K instead of L
    South Carolina
    John and Kris, Lisa has always used the Prodigy wireless brake controller.
    Thanks I gotta do more reading and less typing
    South Carolina
    The Prodigy is a sweet controller and easy enough to set up.  I'm very happy with mine!
    Thanks Mike. If we can get a good trade for our Lexus GX we will get an RX ( Kris wants to downsize) IF the dealership will put a fully functioning 7 pin on her.
    We will use the Prodigy RF as I am sure Lexus will not want to cut wires at the dash.
    Thanks again
    South Carolina
